mgirardo
Mar 22, 2017Explorer
The V10 can certainly handle the extra weight of the Acadia, but you need to make sure the hitch and chassis framing on the motorhome can handle it. Some are rated for 5,000+ lbs, while others are only rated for 3,500 lbs. If yours is only rated for 3,500 lbs, it is most likely because the frame extension is a weak point. You should be able to have some supports welded in to beef up the extension so you can tow the extra weight.
-Michael
-Michael
