Ivylog's avatar
Ivylog
Jan 17, 2017
DIY film removable from front of MH.
I've been putting off starting this project for several years and I'm too cheap to pay $1000 to have it removed. Posted on here that I was going to start and KDK sent me a PM to call him... he was on his second removal and he had found the secret to removing the glue. He said to go to Lowe's and buy Orange Squeeze air freshener... yes a citrus air freshener and it really works. Still takes a fair amount of scraping with a plastic razor blade and it does not soften the clear coat.
I used a heat gun to soften the film and and was able to take it off in razor blade widths fairly quickly... 20" in 45 seconds. I wimped out on doing the two black sections... only doing the 2' X 9' center center section. I wet sanded the black sections and painted them with black plastic paint. You can still see the cracks but only if you get up close and almost straight on. MAYBE next year I'll get motivated to remove the black sections... NOT likely
That
I did not do this all at once but I have 8-10 hours in removing the film/glue and another 6 hours sanding , masking and painting the two black sections.
Here are some pictures:
You can see the strips of film removed and the next strip to be removed.
Finished product.
