An 8 ton hydraulic jack with a screw top will work fine. Go to Sears, Napa, or so on.
Amazon 8-Ton jack $25.You should have a few boards with you to block the tires and maybe for under the jack depending on how high up your jacking point is. You should be able to use the boards you use for leveling.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
