RambleOnNW's avatar
RambleOnNW
Oct 27, 2015
Do you drain the gas out of your Onan Carb?
Recently noticed in the Onan 4000 manual that it has a carburetor gas drain valve below the front of the carburetor. The valve is adjusted using a phillips or slotted screwdriver. The gas drains on the front of the generator, but I found that a 1/4" rubber hose fits the drain port. I used a 1 foot hose to drain however an 18" hose would have allowed draining to a container on the ground. I got 1-2 oz of gas out.
I had not been doing this before without issue. I run the gen once a month though and put Stabil in the gas.. Now I plan to drain the carb when not using it for awhile as further insurance against getting varnished.
Any long term MH storers drain it also?
