Spizzer
Jan 12, 2014Explorer
Old Snipe wrote:
I installed the primer pump on my 07 WB Journey 39K. Plenty of clearance to install it.
When I change the filters, I change the water/separator filter first. I used the primer pump and fill it. Then I start the engine and let it run to get any remaining air through the system. I then replace the secondary filter up on the engine block, fill it with the primer pump and start the engine.
Doing it this way is easier because I don't have to pump the pump handle as much.
Best Regards!
Thanks, Paul. That is good information. I know yours is going to be different, but iit gives me hope.
Jeff
38,707 PostsLatest Activity: Feb 18, 2025
