I have a 1994 Georgie Boy Swinger, owned since new. Have about 235000 miles on the odometer. The door hinge spacers are badly worn and the door has sunk relative to the door frame. This makes openi...
I have done like Mountainair05 mentioned earlier, using a washer or stack of washers, cut a notch out so they will fit over the pin and lift the door and slide them in. I did this to each of the hinges so they shared the weight. I used brass washers hoping they would wear without wearing the steel hinge more and used a dry lube on the hinges. Hope this may help, Happy Trails Bert
