J-Rooster
Nov 05, 2016Explorer
Ivylog wrote:I drove log truck for 14 years and backed up steep gravel hills empty all 14 years (very rarely not able to complete the back up) and the rear of a DP has a lot more weight on the drivers than a empty log truck. I had lots of experience backing up in gravel. In fact once in a while driving up a steep gravel hill forward I would just spin the drivers due to lack of weight on the drivers! So I disagree with your less traction backing up!J-Rooster wrote:
I would back up the driveway!
You have less traction backing up.
OP, if you do not make it up and have to back down, let air out of your four rear tires... 100 down to 60 psi. This requires that you have found the air outlet under the front cap and have a air line long enough to reach your rear tires to air them back up once you make it to the top. You need to have this capability regardless as it's the easiest way to top off your tires.
38,707 PostsLatest Activity: Feb 17, 2025
