garyemunson's avatar
garyemunson
Jan 03, 2018
Dry camping recommendations
We have rarely 'dry camped' with our 2015 Winnebago class A because of the battery issues we have. It came with 2 12 volt deep cycle batteries in parallel and we have found that between some lights, TV watching (with satellite receiver), the electric draw from both the furnace fan and electrical needs of the fridge (on propane) that we run out of 110 from the inverter pretty quickly as the batteries run out of charge. This generally happens in less than 2 hours forcing an early bedtime as to preserve power for the heat and fridge. Hate waking up to a beeping reefer. Starting the generator later in the evening is not something I want to do and disturb others with. Is this to be expected? I've seen quite a few RVs that have 4 6 volt golf cart batteries and was hoping someone here with that setup could enlighten me as to whether that provides enough battery power to relieve the worry of not getting through the night. We have a 2K Magnum inverter and wonder if it's so inefficient making 110VAC that running the generator is just a necessity until quiet hour kicks in. I'd hate to spend a lot of money on batteries if it's not really going to help that much.
