samven1 wrote:
After doing all the research several months ago and deciding I needed the one piece valve stem and then calling around for someone to remove my tires to install them I went with a TPMS that has an in cab display. I still have to pop the hub caps to add air which is a pain but it is really nice to just flip the monitor on 5 min before I leave and read the tire pressure and temp of each tire. It is also very informative to see the temp and pressure change as you heat them up and one big surprise was watching the right hand side heat up and pressure rise going across SD with a strong wind from the left. In the 6 mos I have had them I only had to add air once because of the dropping temps and double check the monitor accuracy against my digital gauge.
They do all read 2 psi lower than my gauge but I am not sure which one is off since 2 psi is within the spec of both.
Or see the difference in tire temp parked with the sun heating up the tires that face it. Couldn't believe that much difference, watched a video showing a Class A with the big tires and they had a Infrared Thermometer showing the tires before sun-up 57 degrees and pressure at 80 all tires.
A couple hours later after the sun had been up they did it again only this time the two tires facing the sun were at 107 degrees and 85 pressure while the other two still in the shaded side were still 57 and 80 pressure...
Got one of those craftsman digital tire gauges for a stocking stuffer a couple yeas back , it reads 3.5 lbs less than 3 other (2 digital and 1 manual) cheap tire gauges I've had for years and yes all three of the gauges are different brands and they all read the same...
I guess so much for craftsman quality :( ...
Didn't mean to get off track but still related ...
