Bobbo
May 11, 2016Explorer II
Depends on how the coach manufacturer wired it. You have to test it to see.
1. Use a VOM to check the voltage of the house battery. Should be about 12.7v if fully charged.
2. Start vehicle, then re-check house battery voltage. If charging, the voltage should be somewhere between 13.6v and 14.4v.
If the voltage goes up, it is being charged. If the voltage does not go up, it is not being charged.
I suspect 95% or more do have the house battery being charged.
38,707 PostsLatest Activity: Feb 18, 2025
