ttharrisons's avatar
ttharrisons
Electric Water Heater
Hi there,
My brother has 2019 Entegra Vision 26x. He’s having a few issues and I wondered if you could help. One issue is the water heater. Using propane, the water gets warm, but on electric, it worked for a little while (a day), but now the water is cold again. Any thoughts on what the issue could be?
Thanks
  • ttharrisons wrote:
    Looks like he’s decided to find a good rv service center in the Bay Area and have them go through the entire rig…seems to be a number of little things going on, and it’s his first rv.
    Tks
    Depending on where in the Bay Area he's looking I would suggest Leale's RV in San Jose - they do great work.
  • without reading all the replies. Old question from a lot of RV sites. "could the valves in the wet bay be open and the valve for the faucet be the only one close?" Hot and cold will mix there
  • Looks like he’s decided to find a good rv service center in the Bay Area and have them go through the entire rig…seems to be a number of little things going on, and it’s his first rv.
    Tks
  • wa8yxm's avatar
    wa8yxm
    One suggestion if replacing the element in an RV water heater may sound strange but read on... The Element is nothing more than a resistor so it's not all that concerned about voltage.. It's more concerned about current (Too much and it's history)
    So get an element rated for 1500 watts at 240 volts..
    What happens if you do this.
    Now I know some RV's are only 1400 watts but 1500 watts at 120 volts is 12.5 amps That's a "Big Load" 1400 is 11 2/3 still a big load
    But that 240 volt 1500 watt.. When you cut the voltage in half you will also cut the current since I=E/R so you get 6.25 amps That's a medium load. and 385 watts.. Takes a bit longer to hot up the water but the temp is controlled by something else (Thermostat) so it will hold it at 120 just fine.
    And on a 30 amp site...MORE amps left over for other stuff.
  • Water from heater should get more then warm.
    I would check the thermostat and ECO and make sure they are tight to the tank.
    Is the water heater tank full of water?
    Make and model of water heater?
  • Mine was 1400 watts, not the standard wattage from stores such as Lowe's.
  • Sounds like a bad element. Any big box store would have one. Just take the old element out and find a matching one at Lowes.
