RonWSl
Aug 05, 2018Explorer
EMS testing and work around
I think I have a bad EMS board on my 2004 HR Vacationer. Nothing in the coach works on shore power or the generator. I was working inside the coach while plugged into 50 amp power and everything just went off - both of the AC's, the ceiling lights, the hot water will not turn on, etc. The breaker panel shows 120 volts coming into the panel on both shore and generator. The EMS is an Intellitec model 760 and the sticker on it says it's the upgraded version. I then tried to find a replacement board online and every vendor I looked at said the boards were out of stock and/or on back order, except on on ebay who is charging twice what everyone else is, although he apparently has them in stock (the old demand and supply at work). Does anyone know if a different board model would work? It has also been suggested that the board could be bypassed, and I am curious if anyone can explain how to do a work-around or bypass the board??? Thanks.
