usersmanual
Aug 29, 2016Explorer
frankiebIII wrote:
Hi all,
I have a 2005 Monaco Diplomat with a 400 hp Cummins diesel, I have owned it for 4 years. It has been problem free and runs great. However, the 4 times I have taken it over the Grape Vine steep grade the engine water temp creeps up over the 200 marker. When it gets to about 225 I start to hear a faint squelching/light beeping sound from by my left leg. As it gets to about 230ish it becomes a full blown beeping sound like when a car door is left open on an automobile. No warning lights come on and my RV is equipd with a engine warning light, a check engine light and a Stop Engine light. As I go down hill the beeping slowly fades as the engine cools until it goes to a light squelch and then disappears. I am assuming this is some sort of warning.
Is it a warning?
Does anyone else get this warning?
Is my engine running too hot?
What can I do to bring the temp down when going up a hill as I do have the peddle all the way down? Should I drop my speed to a crawl like the semis do?
Should I pull over and let engine cool and if I do that do I rust sit and let it idle or turn off engine after it idles a few mins?
Thanks for any education you can offer!
the noise u hear is a factory overheat beeper. 230 is hot.For a short distance no problem,Big question is R U having to add fluids after this or not.Grapevines a long hard pull best to select 4 th gear or 3 rd gear and just slowly pull your way to the top running in the 2-21 rpm area.maybe try running a HP water hose through the CAC and side mounted rad. maybe getting pretty dirty
Have you ever stopped and made sure the fans running full RPM when getting these high temps?
38,705 PostsLatest Activity: Jan 14, 2025
