exterior sunshades
mc4042
We would like to purchase an exterior windshield cover so we can block out the UV rays, keep the inside cooler, and give us privacy. We've been looking online at the Sungard brand and were wondering if anyone has them installed and if so how they like them. We were considering the twist-lock type instead of snaps or velcro.
13 REPLIES 13
mike_brez
Executive wrote:
Mike Brez .... they're NOT holes if they plug them with snaps or twist locks...:B:B...just sayin.....Dennis
Well there seems to be a bunch of other holes in our coaches plugged up with windows,a/c units,vents and so on that seem to cause a bunch of problems when reading these forums.
The last thing I personally want is a dozen more holes with plugs...just sayin...:B
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Executive45
mike_brez
mc4042 wrote:
Thank you everybody for all of your help. Now we have to make a decision.
The only decision to make is if you want some extra holes in your coach or not.
ROTFLMAO
2015 Wrangler JKU
mc4042
Executive45
We had the Sunguard on our Dynasty and loved them. (4 years) When we bought the Executive the first thing we did was have them installed. The RV Toy Store in Palm Springs came out to our campsite, measured, came back the next day and installed them at our campsite. They are now 5 yrs old and look like new. They also come with a nice padded bag to put them in when not in use. We full time so they are on a lot in all kinds of weather. We installed the snap type but I would recommend the twist locks. Also, have the corners wrapped to make it easier to install when it's cold outside. If you need a pic of what I'm saying, let me know.....Dennis
gatorcq
Sun Shade Yes
reflectix insulation between shade (outside) and window = Bigger Yes
reflectix insulation behind window (inside) = Ok, but not as good as above.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
ncrowley
Another vote for Magneshades. No holes and easy to put up and take down. I have been in very strong winds and they have not moved.
Nancy
Newmar Northern Star
bigdog2
We have the sun guard and went with the twist locks because sometimes we get 40 mph winds in the Baja. They work as advertised & we are happy with them.Had them ordered to fit and installed at an rv dealer.
LOW net worth.........HIGH quality of life
Dudley is at the rainbow bridge
Sonney,old ,retired Roadway driver.
Donna, too young to retire, she quit.
2006 GBM Pursuit 3500 DS
2014 ram toad- toad's toad VW powered buggy
Bumpyroad
when I was looking at them years ago, they had the snap type where you drilled holes for the snaps, and also a model with stick on snaps where you didn't have to drill. also magnetic strips.
bumpy
Dale_Traveling
Personally I try and avoid pulling holes in the coach. Already have enough potential factory installed leak points. Magne shades are the easiest to install and least intrusive but being custom made can be a bit hard on the RV budget. I made my own duplicating Magne Shade. Not quite as elegant but gets the job done.
2006 Hurricane 31D built on a 2006 Ford F53
Marine_By_Choic
Magne Shade on our Vegas 24.1 is wonderful.
mike_brez
Magna Shade no holes in coach for snaps or twisty locks.
2015 Wrangler JKU
Trackrig
We installed the Magne Shade on the windshield and the two front side windows. They keep the heat on the outside of MH vs an inside shade that lets the heat on the inside. You can see out of them but it's hard for people to see in. They work well.
Clicky
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
