โMay-20-2013 01:03 PM
โMay-21-2013 09:05 AM
โMay-21-2013 05:01 AM
shaneperch wrote:
Isn't there a gauge on the permenant installed tanks? Or the liquid comes out meaning it's full? I need to get mine filled as well never done it before.
โMay-21-2013 04:28 AM
โMay-20-2013 09:42 PM
โMay-20-2013 08:54 PM
mpfireman wrote:Portable DOT bottle or cylinder and permanently attached ASME tank that is welded to the motorhomes frame. MPfireman, I know you know the difference, but this is for those who don't. I don't know how your going to weight that AMSE tank unless you weight the motorhome first and then fill the tank and re-weight the motorhome again? And when they deliver LP to home heat customers, just how do they weight AMSE tanks?vic46 wrote:
There are two different types of propane reservoirs. The tank type that must be removed from the RV for filling. The vessel type that is permanently mounted on the RV. Both may be filled using a metering system and the tank type may be filled using a weight system. The weight system can not be used for a propane vessel as this system requires the removal of the reservoir from the RV to accommodate weighing the reservoir.
Hooray, some else uses the weight system when filling those portable tanks. The only true way to correctly fill these types of tanks.
โMay-20-2013 06:28 PM
โMay-20-2013 05:46 PM
โMay-20-2013 05:38 PM
Maladjusted wrote:
For the campgrounds that list LP in the ammenities... will they fill your propane tank on the MH?
Do you guys do it when you first pull in if needed?
(I am down to 1/4 tank and am headed down to the OuterBanks, NC this weekend (Cape Hatteras KOA).
Thanks in advance,
Mal
โMay-20-2013 03:14 PM
โMay-20-2013 02:55 PM
โMay-20-2013 02:42 PM
โMay-20-2013 02:38 PM
โMay-20-2013 02:30 PM
โMay-20-2013 02:28 PM
