malexander's avatar
malexander
Fleetwood Bounder Slide
I have a 2007 Fleetwood bounder 38N DP. The kitchen slide and living room slide work fine. The bedroom slide will not extend or retract. It just stopped working. I had all three slides out, on my driveway, while cleaning it up. I retracted all slides, parked the MH under the carport. Bedroom slide won't extend now. The other two operate fine.
I replaced the circuit board, and checked the fuses. I can hear the in/out relay clicking (it's under the bed) when I depress the rocker switch on the wall. At the motor, about 8-10" away, there is a 2-wire molex connector. I disconnected this and "jumped" the wires, directly to the motor, with a hot battery. Slide extended & retracted just fine.
Keep in mind, the other slides are operating fine. So, I'm pretty sure I have all the "safetys" in order. ie. ignition key on, MH level, parking brake engaged, etc.
Any suggestions? Maybe a fuse between the circuit board & the motor?
