Oct-01-2015 09:04 AM
Oct-08-2015 11:18 AM
Oct-03-2015 08:02 AM
Oct-02-2015 08:18 AM
Oct-01-2015 09:13 PM
Oct-01-2015 07:22 PM
pauldub wrote:I read through all the replies. Thanks for sharing your own ideas. I think I will give pauldub, Mike Leslie, and Bea PA's solution a try first. If I have no luck, I will consider the others. And by all means, keep the ideas coming.
I use the same kind that you're using on your windshield. I must have gotten car sized ones and they fit perfectly.
Oct-01-2015 06:01 PM
Oct-01-2015 05:53 PM
Hank85713 wrote:
I use a foil type bubble window cover and took 1 cut in half and made side window covers. We pull in put the front shade in, then add the sides. I use large suction cups to hold them to the windows and have had no problems. Used some 1/2 inch grommets for the holes for the suction cups and got a couple of the key ring wires from ace to pull them off with. Think I spent a total of around $5 for everything.
Easy to install and no seeing in, for the windshield just put the visors down to hold in place.
Oct-01-2015 02:56 PM
Oct-01-2015 01:03 PM
Oct-01-2015 10:29 AM
Oct-01-2015 10:10 AM
Oct-01-2015 09:36 AM
