Katman1100's avatar
Katman1100
Front axle swap 97 E superduty brake line issue
I have just completed the swap of the front axle on my 97 Born Free to the new heavier axle from the 2010+ era chassis. I have run into one issue and that is I need a different brake line for the left/drivers side. I was given part numbers by JD a member here who has also completed this task and provided lots of insight to this task.
The part numbers I have are Dorman H620985 Right and -86 Left. These have been confirmed to be correct for the newer axle. The right side worked great, the problem is the left side has a different fitting at the chassis end. I believe this is because the 97 chassis does not have front anti lock brakes, I am not positive on this.
Has anyone else done this swap on an early chassis like the 97, and if so what brake line did you use on the drivers side? My current line though not the ideal shape would work if it was about an inch longer! I am trying to find an aftermarket one for the earlier chassis that may be slightly longer that what I have. Does anyone have any ideas?
I will post a thread up in the future to hopefully help others who may decide to do this swap in the future or answer any questions.
