btilfan's avatar
btilfan
front cap after red max pro (zep)
Second picture is after 3 coats of zep.
  • I used the Red Max about 5 years and have re coated it three times and last year it started to peel/flake off so will have to remove it and try coating again.
    I believe with so many coats the sun has caused it to begin to flake.
  • Two or three coats on hazy head lights will clear them. It fills in the small scratches. It also works on older cars that have worn clear coats that no longer shine like they once did. I use Redd Maxx on the front and rear caps but hand wax the sides since they still polish up nicely. Works great on rigs with weathering worn finshes that just won't take a shine with normal wax.
  • I'm only doing the front and rear cap as they are kind of chalky. the sides still have some gloss so I plan to use a traditional wax on them.
  • I did the Red Max thing over three years ago and its still holding a great shine. Couple places had to be re applied after time, the door because I didn't prepare it properly before application and the top of the front cap because I get pretty aggressive in my quest to remove the last remnants of any bugs.
