Front wind noise.
garymunson
I think this will apply to many coaches beyond just Fleetwood products. After insulating the underside of my Fleetwood Flair class A doghouse with a dyna-mat type material, The lessened engine and fan noise made wind noise an issue. At first, I though the racket was the wind blowing around the mirrors but using some plastic tubing as a 'stethescope', I determined it was coming from the front side windows. Fleetwood (I cured a friend's Southwind with this solution, too!) uses an aluminum extrusion for the window frame that, along the bottom edge, has holes punched to allow water to drain from the bottom of the track. The windows I'm addressing have a fixed front panel and sliding rear one. The holes in the frame are under both glass panels. Since the front one is fixed in a rubber gasket, drain holes aren't really needed under it. The sliding window, however, does need them as it is set towards the inside of the coach and rain can collect under it. The holes under the sliding panel make very little noise as when the glass is closed, it sits directly above the holes and muffles the noise. The front panel, however, as it is set to the outside of the frame, does not cover the area of the holes. To stop the noise, I simply covered the holes under the front panel on the outside of the coach with a strip of tape. HUGE difference in noise level. There should be no problem with water buildup as the rear holes are still open and that is where the water would enter. Take a look to see if you have the same issue with the drain holes and try this tape trick. After a few rainy days, if there is no problem with water buildup, I'll plug the front holes with sealant! The track runs, unobstructed, from front to rear so water is free to drain to the back.
15 REPLIES 15
Carvin_Marvin
I just taped the front holes yesterday and there is a noticeable noise reduction. Thanks Gary
garymunson
Re-read my post.. I only taped the front holes which I'm sure are only there because the frame material is punched along it's whole length. The rear holes are still open to drain the water that comes in around the sliding window.
Scars
Hey 1BryNelson...pretty funny!
My original engine dog house insulation was in pieces laying on top of the engine when I took it off. I got a roll of aluminum/bubble wrap attic insulation,spray adhesive & a razor blade from Lowes and re-insulated the dog house.
As far as water damage from the taped weep holes, I live in Texas, so rain is rare, the MH lives under a carport and I don't drive in the rain...no damage noted so far but I check from time to time.
The quiet factor is worth it to me :B
'03 Monaco Monarch SE 31'
mike_brez
Effy wrote:
Scars wrote:
I too noticed the noise after adding engine cover insulation and took my trusty ol' black electrical tape and covered the holes...big difference in the noise reduction.
Won't your window frames flood and get water in your interior walls? The weep holes are meant to prevent that exact scenario. The weep hole covers you can buy are open at the bottom to let water out. I think taping them would cause a major issue.
X2 the weep holes are there for a reason.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Effy
Duplicate post
2013 ACE 29.2
Effy
2013 ACE 29.2
hartb1999
my 03 tradition have them on all windows from factoty
D_E_Bishop
DSDP Don wrote:
There are plastic caps for the drain holes. Most are small, about one inch, but Fleetwood seems to use a really long one, about two inches. They snap in and eliminate most of the noise.
I wanted to clean the weep holes on the cab and dinette windows, so I ordered the plastic covers from a dealer and was informed that they are no longer made or my windows. Better check first if you want to buy or if like me you just want to clean the weep holes.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
DSDP_Don
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
1BryNelson
So if I don't do this undercoating I won't notice this problem to begin with. Problem solved.
Bry Nelson and a yet to be discovered MoHo momma. '99 Pace Arrow Vision 37ft F53 chassis (plugs tightened) Allure flooring, 15k BTU front a/c , 6-6 volt batts with 1120 watts of solar Magnum inverter Remote BMK Trace C40 2005 Ford Ranger "Toad on a pad".
WyoTraveler
My MH had factory installed insulation. I guess they do make some improvements to MHs as the years go by.
WILDEBILL308
They sell plugs for the drain holes. You could just fill them with caulk.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
Scars
WyoTraveler
Before I purchased my MH I had driven a couple of different MHs. One was the same model and brand as the one we bought and had wind noise. The one we bought did not have the wind noise. Maybe just construction of the windows?
