fulltimin
Sep 17, 2020Nomad
If this is the rig in your sig, it may or may not have a fuel pump in the tank. A lot of rigs built in that time frame had none in the tank.
However, it may depend on whether or not this has a carb or is fuel injected.
If it has a carb, best place to put the gauge is between the engine mounted fuel pump and the carb.
If it's fuel injection, then usually there was a tank mounted pump, with no pump mounted on the engine.
38,705 PostsLatest Activity: Jan 14, 2025
