JackMS's avatar
JackMS
Furnace not working
My furnace will not come on at all. It is an Atwood 8535IVDCLP. I found the procedure to bypass the thermostat and it works when I do that. So I was about to order a new thermostat but I got thinking.
The thermostat is a dometic 5 button. I replaced the front a/c heat pump about 3 years ago and I had to order an additional circuit board to swap out on the unit to make it work with my thermostat. Both a/c's are dometic penguins. I think I used the furnace since then but am not absolutely positive of that. Is there anything on the roof a/c I should check first or is it most likely the thermostat? If the thermostat is the issue, would I be better ordering the updated thermostat and putting the original board back in the front a/c? Or is it even possible since the rear a/c is the original 2005 model?
I know a lot of questions but I know there are a lot of very experienced a/c guys here. Thanks in advance.
