Trackrig's avatar
Trackrig
Oct 30, 2019
Fuse on a Norcold 1200 refer?
We have a 2005 Fleetwood 39S Excursion with a Norcold 1200 refer in it. We've been told there is a fuse someplace in the back of the 1200. I've done a bit of maintenance on it over the ages and have never seen a fuse on the refer itself. I'd like to find the fuse, identify it, and carry a spare.
Can anyone confirm there is a fuse on the 1200? If yes, please tell me where it is or what it is so I can buy a spare.
Bill
  • Left lower area of circuit board (F3 terminal) is the 120VAC fuse
    It is a fast acting 5 amp 1/4" x 11/4" AGC type.
    Protection for AC Circuit/Elements
    Lower center area of circuit board (F1 terminal) is the 12VDC fuse
    It is an Auto Blade 5A type fuse
    Protection for DC circuits...controls/functions and gas vavle/electrode
  • Keep in mind as has been said, the only purpose of the fuse is to protect the 120v heating elements - there may be two fuses on the 1200. If they blow, you may as well buy a new heating element before you replace the fuse.
    My previous MH had 1200 and it used to trip the GFI when I tried to start the refrigerator to cool it down. It would switch over to propane and cool down before I'd notice the GFI had tripped. After I reset the GFI and the boiler on the 1200 was good a hot, it continued operation on 120v with not issues. The fuses never blew.
  • Thanks. I've had to reset my board also, but didn't notice the fuse as I had other thing on my mind.
    Bill
  • Good luck getting the cover off.
    I had to remove my cover to reset the board and fashioned a cardboard cover to replace the black plastic one.
    Now it's simple to get to my board in case I need to reset it again.
  • If or when the fuse blows, it will be for a reason like a failed 120V heater. Simply replacing a blown fuse wont get you far. BTW, it's under that black plastic cover that houses the circuit board.
