SuicideCharley's avatar
Mar 27, 2015
Gen Battery Suggestions
Hello all, so I brought my 90 Airex home last night YES! I'm in search of recommendations from this great forum on generator batteries. From what I can tell, I'm running an Onen 4000. I believe it takes two batteries. Anyhow, any recommendations would great.
  • JimFromJersey wrote:
    Your genny doesn't "take" batteries, per se. It's starts via either the engine-start battery (often called the 'chassis' battery) or the auxiliary batteries (often called the 'coach' or 'house' batteries). It should, when running, charge the house batteries, and POSSIBLY, but not probably, the engine battery. In most cases, the engine/starting battery is charged by the alternator only, when the engine is running. Once you start the genny, your converter panel should, in a second or two, switch over the current so that your 12v and 120v systems are powered by the generator.
    Interstate makes good batteries. Most people have a 'favorite' battery that may or may not be based on quality. Don't go cheap, though. Keep them charged.
    Here's a hint - in most cases, when your MH is plugged into 120v "shore" power, your house batts are usually kept charged by your converter, but NOT your starting battery. You can buy a cheap diverter for about $20 that steals a little bit of the juice going into your house batteries, and keeps your engine battery charged up at the same time. Highly recommended. BestConverters.com, look for "trick-L start" or something like that.
    THANK YOU Jim! I appreciate the input and tips on the diverter!
  • Your genny doesn't "take" batteries, per se. It's starts via either the engine-start battery (often called the 'chassis' battery) or the auxiliary batteries (often called the 'coach' or 'house' batteries). It should, when running, charge the house batteries, and POSSIBLY, but not probably, the engine battery. In most cases, the engine/starting battery is charged by the alternator only, when the engine is running. Once you start the genny, your converter panel should, in a second or two, switch over the current so that your 12v and 120v systems are powered by the generator.
"}},"componentScriptGroups({\"componentId\":\"custom.widget.CustomFooter\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/EscalatedMessageBanner\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/users/UserLink\"]})":[{"__ref":"CachedAsset:text:en_US-components/users/UserLink-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserRank\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserRank-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageTime-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSolvedBadge\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSubject\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSubject-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageBody\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageBody-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageCustomFields\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageCustomFields-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageReplyButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageReplyButton-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeView/NodeViewCard\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1741694506000"}],"message({\"id\":\"message:1691385\"})":{"__ref":"ForumReplyMessage:message:1691385"},"message({\"id\":\"message:1691384\"})":{"__ref":"ForumReplyMessage:message:1691384"},"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeTopicsCount\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeLatestActivityTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1741694506000"}]},"CachedAsset:pages-1742978771020":{"__typename":"CachedAsset","id":"pages-1742978771020","value":[{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978771020,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Community Alumni","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"MMM-dd-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":null,"possibleValues":["en-US"]}},"deleted":false},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"GroupHub:grouphub:Motorhomes":{"__typename":"GroupHub","id":"grouphub:Motorhomes","entityType":"GROUP_HUB","displayId":"Motorhomes","nodeType":"grouphub","depth":2,"title":"Motorhome Group","shortTitle":"Motorhome Group","parent":{"__ref":"Category:category:TRAVELCENTER"}},"Category:category:top":{"__typename":"Category","id":"category:top","displayId":"top","nodeType":"category","depth":0,"title":"Top"},"Category:category:TRAVELCENTER":{"__typename":"Category","id":"category:TRAVELCENTER","displayId":"TRAVELCENTER","nodeType":"category","depth":1,"parent":{"__ref":"Category:category:top"},"title":"Groups","entityType":"CATEGORY","shortTitle":"Groups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:Motorhomesforum-board":{"__typename":"Forum","id":"board:Motorhomesforum-board","entityType":"FORUM","displayId":"Motorhomesforum-board","nodeType":"board","depth":3,"conversationStyle":"FORUM","title":"Motorhome Group","description":"","avatar":null,"profileSettings":{"__typename":"ProfileSettings","language":null},"parent":{"__ref":"GroupHub:grouphub:Motorhomes"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:feyqc97479"}},{"__typename":"CoreNodeEdge","node":{"__ref":"GroupHub:grouphub:Motorhomes"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"boardPolicies":{"__typename":"BoardPolicies","canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"shortTitle":"Forum","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"REVERSE_PUBLISH_TIME","repliesFormat":"threaded"},"topicsCount":38714,"messageActivity":{"__typename":"MessageActivity","corePropertyChangeTime":"2025-04-10T16:50:17.638-07:00"},"eventPath":"grouphub:Motorhomes/category:TRAVELCENTER/community:feyqc97479board:Motorhomesforum-board/","tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":false,"tagType":"FREEFORM_ONLY"},"Rank:rank:42":{"__typename":"Rank","id":"rank:42","position":35,"name":"Explorer","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:307285":{"__typename":"User","id":"user:307285","uid":307285,"login":"SuicideCharley","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"email":"","messagesCount":17,"biography":null,"topicsCount":4,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-03-25T10:48:46.000-07:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:307285"},"ForumTopicMessage:message:1691383":{"__typename":"ForumTopicMessage","uid":1691383,"subject":"Gen Battery Suggestions","id":"message:1691383","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:307285"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Motorhomesforum-board"},"conversation":{"__ref":"Conversation:conversation:1691383"},"readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:1691383"},"body":"Hello all, so I brought my 90 Airex home last night YES! I'm in search of recommendations from this great forum on generator batteries. From what I can tell, I'm running an Onen 4000. I believe it takes two batteries. Anyhow, any recommendations would great.","body@stringLength":"262","rawBody":"Hello all, so I brought my 90 Airex home last night YES! I'm in search of recommendations from this great forum on generator batteries. From what I can tell, I'm running an Onen 4000. I believe it takes two batteries. Anyhow, any recommendations would great.","kudosSumWeight":0,"postTime":"2015-03-27T12:11:20.000-07:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuMnwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:Class A","text":"Class A","time":"2002-04-24T11:23:54.000-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:1691383_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":636},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"Hello all, so I brought my 90 Airex home last night YES! I'm in search of recommendations from this great forum on generator batteries. From what I can tell, I'm running an Onen 4000. I believe it...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwxNjkxMzg1LDE2OTEzODU","node":{"__ref":"ForumReplyMessage:message:1691385"}},{"__typename":"MessageEdge","cursor":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwxNjkxMzg1LDE2OTEzODQ","node":{"__ref":"ForumReplyMessage:message:1691384"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Conversation:conversation:1691383":{"__typename":"Conversation","id":"conversation:1691383","solved":false,"topic":{"__ref":"ForumTopicMessage:message:1691383"},"lastPostingActivityTime":"2015-03-27T13:19:28.000-07:00","lastPostTime":"2015-03-27T13:19:28.000-07:00","unreadReplyCount":2,"isSubscribed":false},"ModerationData:moderation_data:1691383":{"__typename":"ModerationData","id":"moderation_data:1691383","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:1691383_1":{"__typename":"Revision","id":"revision:1691383_1","lastEditTime":"2015-03-27T12:11:20.000-07:00"},"CachedAsset:theme:customTheme1-1742978770583":{"__typename":"CachedAsset","id":"theme:customTheme1-1742978770583","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"RGB-GoodSam-Emblem-TM-Solid-SignageGreen-1709848693343.png","imageLastModified":"1709848695145","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"4C-GoodSam-Horiz-TM_SignageGreen-1709842742388.png","imageLastModified":"1709842744704","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1250px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"4px","borderRadius":"4px","borderRadiusLg":"4px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-body-color)","secondaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-300)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-body-color)","tertiaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), var(--lia-bs-body-color-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), var(--lia-bs-body-color-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-white)","destructiveTextHoverColor":"var(--lia-bs-white)","destructiveTextActiveColor":"var(--lia-bs-white)","destructiveBgColor":"var(--lia-bs-danger)","destructiveBgHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.85))","destructiveBgActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.7))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#23410A","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#23410A","blogColor":"#D6D6CE","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#C7B197","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#CBCBCB","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#232323","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#23410A","secondary":"#333333","bodyText":"#232323","bodyBg":"#FFFFFF","info":"#23410A","success":"#39842B","warning":"#C3FF49","danger":"#C30B24","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#C7B197","#D6D6CE","#CBCBCB","#C3FF49","#C30B24","#F2EDEB"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Aeonik Pro","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"56px","h2FontSize":"45px","h3FontSize":"38px","h4FontSize":"32px","h5FontSize":"26px","h6FontSize":"24px","lineHeight":"1.3","subHeaderFontSize":"18px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-white)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Aeonik","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"18px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"16px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Aeonik","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"700","__typename":"FontStyleData"}],"assetNames":["Aeonik-normal-400.woff2","Aeonik-italic-400.woff2","Aeonik-normal-700.woff2","Aeonik-italic-700.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Aeonik Pro","styles":[{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["AeonikPro-normal-700.woff2","AeonikPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1741694506000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:campingworld.prod:pages/forums/ForumMessagePage:board:Motorhomesforum-board-1743519515652":{"__typename":"CachedAsset","id":"quilt:campingworld.prod:pages/forums/ForumMessagePage:board:Motorhomesforum-board-1743519515652","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"nodes.widget.nodeActionButtonWidget","className":null,"props":{"buttonAlignment":"right","instanceId":null,"buttonStyle":"md","actionButtonTitle":"Start a New Discussion","lazyLoad":false,"buttonWidth":"full_width"},"__typename":"QuiltComponent"},{"id":"nodes.widget.nodeInformationWidget","className":null,"props":{"instanceId":null,"useWidgetTitle":true,"viewVariant":{"type":"card","props":{"useNodePostCount":true,"useNodeFollowersCount":false,"useNodeDescription":true,"useNodeTopicsCount":false,"useNodeAction":true,"useNodeMembersCount":false,"useNodeMembershipType":false,"useNodeTitle":false,"useNodeMembersCountText":false,"useNodeMembership":false,"useNodeCreationDate":false,"textAlignment":"center","useWidgetTitle":true,"useNodeOwners":false,"useNodeAvatar":false,"useNodeLatestActivityTime":true,"descriptionClampLines":2,"useClickableCard":false}},"alignment":"center","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","useAuthorLoginLink":true,"useNodeLink":true,"usePreviewMedia":true,"timeStampType":"postTime","useTextBody":true,"useSolvedBadge":false,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useVideoPreview":false,"portraitClampBodyLines":3,"useCompactSpacing":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"useAuthorLogin":true}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1741694506000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1741694506000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:campingworld.prod:Common:1742978668313":{"__typename":"CachedAsset","id":"quiltWrapper:campingworld.prod:Common:1742978668313","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":true,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[{"children":[],"linkType":"EXTERNAL","id":"migrated-link-7","url":"https://www.goodsam.com","target":"BLANK"},{"children":[],"linkType":"EXTERNAL","id":"migrated-link-8","url":"https://myaccount.goodsam.com/myrewards","target":"BLANK"}],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"migrated-link-0","params":{"categoryId":"RVTalk"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-1","params":{"categoryId":"TRAVELCENTER"},"routeName":"CategoryPage"},{"children":[],"linkType":"EXTERNAL","id":"Common-external-link","url":"https://community.goodsam.com/category/top/events/events","target":"SELF"},{"children":[{"linkType":"INTERNAL","id":"Common-announcements_blog-link","params":{"boardId":"Announcements_Blog","categoryId":"top"},"routeName":"BlogBoardPage"},{"linkType":"INTERNAL","id":"Common-get-support-ask-questions-link","params":{"boardId":"GetSupportAskQuestions","categoryId":"top"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Common-community-feedback-link","params":{"boardId":"CommunityFeedback","categoryId":"top"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-3","params":{"boardId":"Announcements_Blog","categoryId":"top"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"INTERNAL","id":"Common-admin-mods-private-link","params":{"categoryId":"AdminModsPrivate"},"routeName":"CategoryPage"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"var(--lia-bs-body-color)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"16px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"30px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"15px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"notFound","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"notFound","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid var(--lia-bs-primary)","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"15px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-gray-600)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-black)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.CustomFooter","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1741694506000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.CustomFooter-en-1742978782374":{"__typename":"CachedAsset","id":"component:custom.widget.CustomFooter-en-1742978782374","value":{"component":{"id":"custom.widget.CustomFooter","template":{"id":"CustomFooter","markupLanguage":"HANDLEBARS","style":"$bootstrap-padding: 15px;\n$goodsam-gray: #474442;\n$goodsam-gray-200: #eaecef;\n$goodsam-gray-400: #c7c7c7;\n$goodsam-gray-700: #666;\n$goodsam-gray-footer: #dfdfdf;\n\n$theme-type-size-xsmall: 12px;\n$theme-type-size-small: 14px;\n$theme-type-size-base: 16px;\n$theme-type-size-large: 18px;\n$theme-type-size-xlarge: 20px;\n\n$font-weight-content: 100;\n\n$theme-space-xsmall: 5px;\n$theme-space-small: 10px;\n$theme-space-base: 20px;\n$theme-space-large: 40px;\n$theme-space-xlarge: 60px;\n.footer-wrapper {\n background: $goodsam-gray;\n\n a {\n color: $goodsam-gray-footer;\n font-weight: $font-weight-content;\n\n &:focus,\n &:hover {\n color: $goodsam-gray-footer;\n }\n }\n}\n.sr-only {\n position: absolute;\n width: 1px;\n height: 1px;\n margin: -1px;\n padding: 0;\n overflow: hidden;\n clip: rect(0, 0, 0, 0);\n border: 0;\n}\n.footer {\n line-height: $theme-type-size-xlarge;\n /* margin-left: auto;\n\tmargin-right: auto;\n\tpadding-left: $bootstrap-padding;\n\tpadding-right: $bootstrap-padding; */\n}\n\n.container {\n margin-left: auto;\n margin-right: auto;\n max-width: 1170px;\n padding-left: $bootstrap-padding;\n padding-right: $bootstrap-padding;\n}\n\n.row {\n /* HOTFIX - PSDS-32115 - Remove negative margins to fix mobile display */\n\n &::after {\n clear: both;\n }\n\n &::after,\n &::before {\n content: ' ';\n display: table;\n }\n}\n\n.col {\n float: left;\n min-height: 1px;\n padding-left: $bootstrap-padding;\n padding-right: $bootstrap-padding;\n position: relative;\n}\n\n.col-xs-10,\n.col-sm-10 {\n width: 83.33333333%;\n}\n\n.col-xs-12,\n.col-sm-4,\n.col-sm-12,\n.col-md-2,\n.col-md-8,\n.col-md-10,\n.col-md-12,\n.col-lg-2,\n.col-lg-8,\n.col-lg-12 {\n width: 100%;\n}\n\n@media screen and (min-width: 767px) {\n .col-md-2 {\n width: 16.66666667%;\n }\n\n .col-md-8 {\n width: 66.66666667%;\n }\n\n .col-md-10 {\n width: 83.33333333%;\n }\n\n .col-md-12 {\n width: 100%;\n }\n}\n\n@media screen and (min-width: 992px) {\n .col-lg-2 {\n width: 16.66666667%;\n }\n\n .col-lg-4 {\n /* faking it; should be 33.33333333% */\n width: 25%;\n }\n\n .col-lg-8 {\n /* faking it; should be 66.66666667% */\n width: 75%;\n }\n\n .col-lg-10 {\n width: 83.33333333%;\n }\n\n .col-lg-12 {\n width: 100%;\n }\n}\n\n.pull-left {\n float: left;\n width: 100%;\n\n @media screen and (min-width: 767px) {\n float: none;\n width: auto;\n }\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n}\n\n.pad-bottom-20 {\n padding-bottom: $theme-space-base;\n}\n\n.pad-top-20 {\n padding-top: $theme-space-base;\n}\n\n.pad-top-30 {\n padding-top: calc($bootstrap-padding * 2);\n}\n\n.pad-top-40 {\n @media screen and (min-width: 992px) {\n padding-top: $theme-space-large;\n }\n}\n\n.margin-left-20 {\n @media screen and (min-width: 992px) {\n margin-left: $theme-space-base;\n }\n}\n\n.margin-top-20 {\n @media screen and (min-width: 992px) {\n margin-top: $theme-space-base;\n }\n}\n\n.text-center {\n text-align: center;\n}\n\n.text-right {\n text-align: right;\n}\n\n.text-smaller,\n.text-small {\n font-size: $theme-type-size-xsmall;\n}\n\n.text-large {\n font-size: $theme-type-size-xlarge;\n}\n\n.footer-contact {\n p {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n .text-small {\n @media screen and (max-width: 991px) {\n font-size: $theme-type-size-base;\n }\n }\n }\n\n .icon-gs-app {\n margin-right: $theme-space-base;\n max-width: 38px;\n padding-right: 2px;\n padding-top: 2px;\n\n @media screen and (min-width: 992px) {\n margin-left: 140px;\n margin-right: 0;\n }\n }\n\n .gsi-icon-phone {\n margin-bottom: -2px;\n margin-right: $theme-space-small;\n max-height: 20px;\n width: 20px;\n\n @media screen and (min-width: 992px) {\n margin-right: 0;\n }\n }\n}\n\n.footer-link {\n a,\n button {\n color: $goodsam-gray-footer;\n padding: 0 12px 0 $theme-space-small;\n }\n\n li:last-child a {\n padding-right: 0;\n }\n}\n\n.footer-top-links {\n padding-left: 0;\n list-style: none;\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n margin-bottom: $theme-space-small;\n font-size: 16px;\n\n @media screen and (max-width: 480px) {\n flex-direction: column;\n }\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n margin-bottom: $theme-space-base;\n padding: 0 $theme-space-base;\n\n @media screen and (min-width: 992px) {\n padding: 0;\n }\n }\n}\n\n.footer-top {\n border-bottom: 2px solid $goodsam-gray-400;\n display: block;\n margin: auto;\n padding-top: $theme-space-small;\n text-align: center;\n\n @media screen and (min-width: 992px) {\n text-align: left;\n }\n\n .footer-logo {\n max-height: 60px;\n max-width: 140px;\n padding: $theme-space-small;\n padding-left: 0;\n padding-top: 0;\n }\n\n .footer-list {\n display: flex;\n justify-content: center;\n align-items: center;\n list-style: none;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n float: right;\n }\n\n li {\n display: inline-block;\n padding: $theme-space-small $theme-space-xsmall;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid $goodsam-gray-700;\n float: left;\n padding: 0;\n\n &:last-child {\n border-right: 0;\n }\n }\n\n a,\n button {\n font-size: $theme-type-size-xsmall;\n text-transform: uppercase;\n\n @media screen and (max-width: 768px) {\n display: block;\n padding: $theme-space-small;\n }\n\n @media screen and (min-width: 992px) {\n font-size: $theme-type-size-small;\n }\n }\n\n .dropup {\n background-clip: padding-box;\n border: none;\n font-size: $theme-type-size-small;\n list-style: none;\n padding-left: 5px;\n position: relative;\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n\n &:hover {\n .dropdown-menu {\n display: block;\n }\n }\n }\n\n .footer-dropup-toggle {\n background: none;\n border: 0;\n padding: 0;\n\n .fa-angle-up {\n /* @include li-icon ($fa-var-angle-up, $pseudo: before, $size: $theme-type-size-base, $color: $goodsam-gray-footer);\n padding-left: $theme-space-xsmall;\n padding-right: $theme-space-xsmall; */\n }\n }\n\n .dropdown-menu {\n background-color: #fff;\n border-radius: 4px;\n bottom: 100%;\n margin: 2px 0 0;\n min-width: 160px;\n padding: $theme-space-xsmall 0;\n position: absolute;\n right: 0;\n\n li {\n border-right: 0;\n float: none;\n text-align: left;\n\n @media screen and (max-width: 768px) {\n display: block;\n }\n\n a {\n color: $goodsam-gray;\n display: block;\n text-transform: none;\n\n &:hover {\n outline: 5px auto -webkit-focus-ring-color;\n outline-offset: -2px;\n }\n }\n }\n }\n }\n }\n}\n\n.footer-terms {\n display: flex;\n flex-direction: column;\n justify-content: center;\n align-items: center;\n padding: $theme-space-small 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n padding: 0;\n }\n\n > .row {\n padding-bottom: $theme-space-small;\n\n @media screen and (min-width: 992px) {\n padding-bottom: $theme-space-base;\n }\n\n &.footer-terms-order-1 {\n order: 1;\n }\n\n &.footer-terms-order-2 {\n order: 2;\n }\n }\n}\n\n.footer-bottom {\n @media screen and (min-width: 992px) {\n padding-top: $theme-space-small;\n }\n\n .footer-bottom-list-center {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n float: none;\n margin: 0 auto;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n display: inline;\n padding: 0 $theme-space-base;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid $goodsam-gray-700;\n padding: 0;\n\n &:first-child a {\n padding-left: 0;\n }\n\n &:last-child {\n border-right: 0;\n\n a {\n padding-right: 0;\n }\n }\n }\n\n a {\n display: inline-block;\n font-size: $theme-type-size-small;\n padding: $theme-space-small;\n\n @media screen and (min-width: 992px) {\n display: inline;\n font-size: $theme-type-size-xsmall;\n padding: 0 12px 0 $theme-space-small;\n }\n }\n }\n }\n}\n\n.copyright {\n color: $goodsam-gray-footer;\n font-size: $theme-type-size-base;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n margin-bottom: $theme-space-small;\n }\n}\n\n#gsFooterSocial,\n.gsFooterSocial {\n background: $goodsam-gray-200;\n padding: 0 calc($theme-space-small + $theme-space-xsmall);\n .footerSocialItems,\n #footerSocialItems {\n text-align: center;\n\n @media screen and (min-width: 767px) {\n text-align: left;\n }\n }\n\n .footerSocialItems ul,\n #footerSocialItems ul {\n list-style-type: none;\n margin: auto;\n padding-left: 0;\n\n li {\n display: inline;\n margin: 0 $theme-space-small;\n }\n }\n}\n","texts":{"custom.footer.col01.text.01":"Home","custom.footer.col01.url.01":"https://www.goodsam.com/","custom.footer.col01.text.02":"About Us","custom.footer.col01.url.02":"https://www.goodsam.com/about/","custom.footer.col01.text.03":"Contact Us","custom.footer.col01.url.03":"https://www.goodsam.com/contact","custom.footer.col01.text.04":"FAQ","custom.footer.col01.url.04":"https://www.goodsam.com/faq/","custom.footer.col01.text.05":"Site Map","custom.footer.col01.url.05":"https://www.goodsam.com/site-map.aspx","custom.footer.col02.text.01":"Code of Conduct","custom.footer.col02.url.01":"https://www.goodsam.com/code-of-conduct.aspx","custom.footer.col02.text.02":"Affiliate Program","custom.footer.col02.url.02":"https://www.goodsam.com/affiliate/","custom.footer.col02.text.03":"Become a Good Sam Campground","custom.footer.col02.url.03":"https://www.goodsamnetwork.com/","custom.footer.col02.text.04":"Good Sam Rewards Visa","custom.footer.col02.url.04":"https://www.goodsam.com/creditcard/","custom.footer.col02.text.05":"About Marcus Lemonis","custom.footer.col02.url.05":"https://www.goodsam.com/about-marcus-lemonis/","custom.footer.col03.text.01":"RV Sales","custom.footer.col03.url.01":"https://rv.campingworld.com/","custom.footer.col03.text.02":"RV Gear","custom.footer.col03.url.02":"https://www.campingworld.com/shop/","custom.footer.col03.text.03":"RV Maintenance & Repair","custom.footer.col03.url.03":"https://rv.campingworld.com/service/","custom.footer.col03.text.04":"Good Sam Membership & Services","custom.footer.col03.url.04":"https://www.goodsam.com/","custom.footer.col03.text.05":"Campground Solutions","custom.footer.col03.url.05":"https://campgroundsolutions.goodsam.com/","custom.footer.col04.text.01":"Helpful Articles and Tips","custom.footer.col04.url.01":"https://www.goodsam.com/article","custom.footer.col05.text.01":"Good Sam Apps","custom.footer.col05.url.01":"https://www.goodsam.com/rv-camping-apps/","custom.footer.col05.text.02":"Take Good Sam apps on your next RV Trip!","custom.footer.col05.url.02":"https://www.goodsam.com/rv-camping-apps/","custom.footer.col06.text.01":"Customer Service Phone Number:","custom.footer.col06.phone.number":"866-205-7451","custom.footer.col06.text.02":"Club contact number 866-205-7451","custom.footer.col06.url.02":"tel:866-205-7451","custom.footer.row01.logo.text":"Good Sam Home","custom.footer.row01.text.01":"Blog","custom.footer.row01.url.01":"http://blog.goodsam.com/","custom.footer.row01.text.02":"Careers","custom.footer.row01.url.02":"https://www.campingworldcareers.com/","custom.footer.row01.text.03":"Contact Us","custom.footer.row01.text.toggle":"Click to expand","custom.footer.row01.text.04":"Good Sam","custom.footer.row01.url.04":"https://www.goodsam.com/contact/","custom.footer.row01.text.05":"Camping World","custom.footer.row01.url.05":"https://www.campingworld.com/contact/","custom.footer.row01.text.06":"RV Sales","custom.footer.row01.url.06":"https://rv.campingworld.com/contact","custom.footer.row02.text.01":"Privacy Policy","custom.footer.row02.url.01":"https://www.goodsam.com/privacy-policy.aspx","custom.footer.row02.text.02":"California Privacy Rights","custom.footer.row02.url.02":"https://www.goodsam.com/privacy-policy.aspx#calinevada","custom.footer.row02.text.03":"Investor Relations","custom.footer.row02.url.03":"http://investor.campingworld.com","custom.footer.row02.text.04":"Terms of Use","custom.footer.row02.url.04":"https://www.goodsam.com/terms.aspx","custom.footer.row02.text.05":"Accessibility Commitment","custom.footer.row02.url.05":"https://www.goodsam.com/accessibility-commitment.aspx","custom.footer.row02.text.06":"Team Member Assistance","custom.footer.row02.url.06":"https://www.goodsam.com/helping-hand","custom.footer.social.facebook.text":"Facebook","custom.footer.social.facebook.url":"https://www.facebook.com/GoodSam","custom.footer.social.twitter.text":"Twitter","custom.footer.social.twitter.url":"https://twitter.com/GoodSam","custom.footer.social.youtube.text":"YouTube","custom.footer.social.youtube.url":"https://www.youtube.com/user/goodsamrvers","custom.footer.social.instagram.text":"Instagram","custom.footer.social.instagram.url":"https://www.instagram.com/goodsam/?hl=en","custom.footer.social.pinterest.text":"Pinterest","custom.footer.social.pinterest.url":"https://www.pinterest.com/goodsam/","custom-community-footer-copyright.text":"© {0} Good Sam Enterprises, LLC. All rights reserved."},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.CustomFooter","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":{"css":".custom_widget_CustomFooter_footer-wrapper_hp49n_21 {\n background: #474442;\n\n a {\n color: #dfdfdf;\n font-weight: 100;\n\n &:focus,\n &:hover {\n color: #dfdfdf;\n }\n }\n}\n.custom_widget_CustomFooter_sr-only_hp49n_34 {\n position: absolute;\n width: 0.0625rem;\n height: 0.0625rem;\n margin: -0.0625rem;\n padding: 0;\n overflow: hidden;\n clip: rect(0, 0, 0, 0);\n border: 0;\n}\n.custom_widget_CustomFooter_footer_hp49n_21 {\n line-height: 1.25rem;\n /* margin-left: auto;\n\tmargin-right: auto;\n\tpadding-left: $bootstrap-padding;\n\tpadding-right: $bootstrap-padding; */\n}\n.custom_widget_CustomFooter_container_hp49n_52 {\n margin-left: auto;\n margin-right: auto;\n max-width: 73.125rem;\n padding-left: 0.9375rem;\n padding-right: 0.9375rem;\n}\n.custom_widget_CustomFooter_row_hp49n_60 {\n /* HOTFIX - PSDS-32115 - Remove negative margins to fix mobile display */\n\n &::after {\n clear: both;\n }\n\n &::after,\n &::before {\n content: ' ';\n display: table;\n }\n}\n.custom_widget_CustomFooter_col_hp49n_74 {\n float: left;\n min-height: 0.0625rem;\n padding-left: 0.9375rem;\n padding-right: 0.9375rem;\n position: relative;\n}\n.custom_widget_CustomFooter_col-xs-10_hp49n_82,\n.custom_widget_CustomFooter_col-sm-10_hp49n_83 {\n width: 83.33333333%;\n}\n.custom_widget_CustomFooter_col-xs-12_hp49n_87,\n.custom_widget_CustomFooter_col-sm-4_hp49n_88,\n.custom_widget_CustomFooter_col-sm-12_hp49n_89,\n.custom_widget_CustomFooter_col-md-2_hp49n_90,\n.custom_widget_CustomFooter_col-md-8_hp49n_91,\n.custom_widget_CustomFooter_col-md-10_hp49n_92,\n.custom_widget_CustomFooter_col-md-12_hp49n_93,\n.custom_widget_CustomFooter_col-lg-2_hp49n_94,\n.custom_widget_CustomFooter_col-lg-8_hp49n_95,\n.custom_widget_CustomFooter_col-lg-12_hp49n_96 {\n width: 100%;\n}\n@media screen and (min-width: 767px) {\n .custom_widget_CustomFooter_col-md-2_hp49n_90 {\n width: 16.66666667%;\n }\n\n .custom_widget_CustomFooter_col-md-8_hp49n_91 {\n width: 66.66666667%;\n }\n\n .custom_widget_CustomFooter_col-md-10_hp49n_92 {\n width: 83.33333333%;\n }\n\n .custom_widget_CustomFooter_col-md-12_hp49n_93 {\n width: 100%;\n }\n}\n@media screen and (min-width: 992px) {\n .custom_widget_CustomFooter_col-lg-2_hp49n_94 {\n width: 16.66666667%;\n }\n\n .custom_widget_CustomFooter_col-lg-4_hp49n_123 {\n /* faking it; should be 33.33333333% */\n width: 25%;\n }\n\n .custom_widget_CustomFooter_col-lg-8_hp49n_95 {\n /* faking it; should be 66.66666667% */\n width: 75%;\n }\n\n .custom_widget_CustomFooter_col-lg-10_hp49n_133 {\n width: 83.33333333%;\n }\n\n .custom_widget_CustomFooter_col-lg-12_hp49n_96 {\n width: 100%;\n }\n}\n.custom_widget_CustomFooter_pull-left_hp49n_142 {\n float: left;\n width: 100%;\n\n @media screen and (min-width: 767px) {\n float: none;\n width: auto;\n }\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n}\n.custom_widget_CustomFooter_pad-bottom-20_hp49n_156 {\n padding-bottom: 1.25rem;\n}\n.custom_widget_CustomFooter_pad-top-20_hp49n_160 {\n padding-top: 1.25rem;\n}\n.custom_widget_CustomFooter_pad-top-30_hp49n_164 {\n padding-top: calc(0.9375rem * 2);\n}\n.custom_widget_CustomFooter_pad-top-40_hp49n_168 {\n @media screen and (min-width: 992px) {\n padding-top: 2.5rem;\n }\n}\n.custom_widget_CustomFooter_margin-left-20_hp49n_174 {\n @media screen and (min-width: 992px) {\n margin-left: 1.25rem;\n }\n}\n.custom_widget_CustomFooter_margin-top-20_hp49n_180 {\n @media screen and (min-width: 992px) {\n margin-top: 1.25rem;\n }\n}\n.custom_widget_CustomFooter_text-center_hp49n_186 {\n text-align: center;\n}\n.custom_widget_CustomFooter_text-right_hp49n_190 {\n text-align: right;\n}\n.custom_widget_CustomFooter_text-smaller_hp49n_194,\n.custom_widget_CustomFooter_text-small_hp49n_194 {\n font-size: 0.75rem;\n}\n.custom_widget_CustomFooter_text-large_hp49n_199 {\n font-size: 1.25rem;\n}\n.custom_widget_CustomFooter_footer-contact_hp49n_203 {\n p {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n .custom_widget_CustomFooter_text-small_hp49n_194 {\n @media screen and (max-width: 991px) {\n font-size: 1rem;\n }\n }\n }\n\n .custom_widget_CustomFooter_icon-gs-app_hp49n_221 {\n margin-right: 1.25rem;\n max-width: 2.375rem;\n padding-right: 0.125rem;\n padding-top: 0.125rem;\n\n @media screen and (min-width: 992px) {\n margin-left: 8.75rem;\n margin-right: 0;\n }\n }\n\n .custom_widget_CustomFooter_gsi-icon-phone_hp49n_233 {\n margin-bottom: -0.125rem;\n margin-right: 0.625rem;\n max-height: 1.25rem;\n width: 1.25rem;\n\n @media screen and (min-width: 992px) {\n margin-right: 0;\n }\n }\n}\n.custom_widget_CustomFooter_footer-link_hp49n_245 {\n a,\n button {\n color: #dfdfdf;\n padding: 0 0.75rem 0 0.625rem;\n }\n\n li:last-child a {\n padding-right: 0;\n }\n}\n.custom_widget_CustomFooter_footer-top-links_hp49n_257 {\n padding-left: 0;\n list-style: none;\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n margin-bottom: 0.625rem;\n font-size: 1rem;\n\n @media screen and (max-width: 480px) {\n flex-direction: column;\n }\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n margin-bottom: 1.25rem;\n padding: 0 1.25rem;\n\n @media screen and (min-width: 992px) {\n padding: 0;\n }\n }\n}\n.custom_widget_CustomFooter_footer-top_hp49n_257 {\n border-bottom: 2px solid #c7c7c7;\n display: block;\n margin: auto;\n padding-top: 0.625rem;\n text-align: center;\n\n @media screen and (min-width: 992px) {\n text-align: left;\n }\n\n .custom_widget_CustomFooter_footer-logo_hp49n_297 {\n max-height: 3.75rem;\n max-width: 8.75rem;\n padding: 0.625rem;\n padding-left: 0;\n padding-top: 0;\n }\n\n .custom_widget_CustomFooter_footer-list_hp49n_305 {\n display: flex;\n justify-content: center;\n align-items: center;\n list-style: none;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n float: right;\n }\n\n li {\n display: inline-block;\n padding: 0.625rem 0.3125rem;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid #666;\n float: left;\n padding: 0;\n\n &:last-child {\n border-right: 0;\n }\n }\n\n a,\n button {\n font-size: 0.75rem;\n text-transform: uppercase;\n\n @media screen and (max-width: 768px) {\n display: block;\n padding: 0.625rem;\n }\n\n @media screen and (min-width: 992px) {\n font-size: 0.875rem;\n }\n }\n\n .custom_widget_CustomFooter_dropup_hp49n_346 {\n background-clip: padding-box;\n border: none;\n font-size: 0.875rem;\n list-style: none;\n padding-left: 0.3125rem;\n position: relative;\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n\n &:hover {\n .custom_widget_CustomFooter_dropdown-menu_hp49n_359 {\n display: block;\n }\n }\n }\n\n .custom_widget_CustomFooter_footer-dropup-toggle_hp49n_365 {\n background: none;\n border: 0;\n padding: 0;\n\n .custom_widget_CustomFooter_fa-angle-up_hp49n_370 {\n /* @include li-icon ($fa-var-angle-up, $pseudo: before, $size: $theme-type-size-base, $color: $goodsam-gray-footer);\n padding-left: $theme-space-xsmall;\n padding-right: $theme-space-xsmall; */\n }\n }\n\n .custom_widget_CustomFooter_dropdown-menu_hp49n_359 {\n background-color: #fff;\n border-radius: 0.25rem;\n bottom: 100%;\n margin: 0.125rem 0 0;\n min-width: 10rem;\n padding: 0.3125rem 0;\n position: absolute;\n right: 0;\n\n li {\n border-right: 0;\n float: none;\n text-align: left;\n\n @media screen and (max-width: 768px) {\n display: block;\n }\n\n a {\n color: #474442;\n display: block;\n text-transform: none;\n\n &:hover {\n outline: 5px auto -webkit-focus-ring-color;\n outline-offset: -2px;\n }\n }\n }\n }\n }\n }\n}\n.custom_widget_CustomFooter_footer-terms_hp49n_412 {\n display: flex;\n flex-direction: column;\n justify-content: center;\n align-items: center;\n padding: 0.625rem 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n padding: 0;\n }\n\n > .custom_widget_CustomFooter_row_hp49n_60 {\n padding-bottom: 0.625rem;\n\n @media screen and (min-width: 992px) {\n padding-bottom: 1.25rem;\n }\n\n &.custom_widget_CustomFooter_footer-terms-order-1_hp49n_431 {\n order: 1;\n }\n\n &.custom_widget_CustomFooter_footer-terms-order-2_hp49n_435 {\n order: 2;\n }\n }\n}\n.custom_widget_CustomFooter_footer-bottom_hp49n_441 {\n @media screen and (min-width: 992px) {\n padding-top: 0.625rem;\n }\n\n .custom_widget_CustomFooter_footer-bottom-list-center_hp49n_446 {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n float: none;\n margin: 0 auto;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n display: inline;\n padding: 0 1.25rem;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid #666;\n padding: 0;\n\n &:first-child a {\n padding-left: 0;\n }\n\n &:last-child {\n border-right: 0;\n\n a {\n padding-right: 0;\n }\n }\n }\n\n a {\n display: inline-block;\n font-size: 0.875rem;\n padding: 0.625rem;\n\n @media screen and (min-width: 992px) {\n display: inline;\n font-size: 0.75rem;\n padding: 0 0.75rem 0 0.625rem;\n }\n }\n }\n }\n}\n.custom_widget_CustomFooter_copyright_hp49n_495 {\n color: #dfdfdf;\n font-size: 1rem;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n margin-bottom: 0.625rem;\n }\n}\n#custom_widget_CustomFooter_gsFooterSocial_hp49n_506,\n.custom_widget_CustomFooter_gsFooterSocial_hp49n_506 {\n background: #eaecef;\n padding: 0 calc(0.625rem + 0.3125rem);\n .custom_widget_CustomFooter_footerSocialItems_hp49n_509,\n #custom_widget_CustomFooter_footerSocialItems_hp49n_509 {\n text-align: center;\n\n @media screen and (min-width: 767px) {\n text-align: left;\n }\n }\n\n .custom_widget_CustomFooter_footerSocialItems_hp49n_509 ul,\n #custom_widget_CustomFooter_footerSocialItems_hp49n_509 ul {\n list-style-type: none;\n margin: auto;\n padding-left: 0;\n\n li {\n display: inline;\n margin: 0 0.625rem;\n }\n }\n}\n","tokens":{"footer-wrapper":"custom_widget_CustomFooter_footer-wrapper_hp49n_21","sr-only":"custom_widget_CustomFooter_sr-only_hp49n_34","footer":"custom_widget_CustomFooter_footer_hp49n_21","container":"custom_widget_CustomFooter_container_hp49n_52","row":"custom_widget_CustomFooter_row_hp49n_60","col":"custom_widget_CustomFooter_col_hp49n_74","col-xs-10":"custom_widget_CustomFooter_col-xs-10_hp49n_82","col-sm-10":"custom_widget_CustomFooter_col-sm-10_hp49n_83","col-xs-12":"custom_widget_CustomFooter_col-xs-12_hp49n_87","col-sm-4":"custom_widget_CustomFooter_col-sm-4_hp49n_88","col-sm-12":"custom_widget_CustomFooter_col-sm-12_hp49n_89","col-md-2":"custom_widget_CustomFooter_col-md-2_hp49n_90","col-md-8":"custom_widget_CustomFooter_col-md-8_hp49n_91","col-md-10":"custom_widget_CustomFooter_col-md-10_hp49n_92","col-md-12":"custom_widget_CustomFooter_col-md-12_hp49n_93","col-lg-2":"custom_widget_CustomFooter_col-lg-2_hp49n_94","col-lg-8":"custom_widget_CustomFooter_col-lg-8_hp49n_95","col-lg-12":"custom_widget_CustomFooter_col-lg-12_hp49n_96","col-lg-4":"custom_widget_CustomFooter_col-lg-4_hp49n_123","col-lg-10":"custom_widget_CustomFooter_col-lg-10_hp49n_133","pull-left":"custom_widget_CustomFooter_pull-left_hp49n_142","pad-bottom-20":"custom_widget_CustomFooter_pad-bottom-20_hp49n_156","pad-top-20":"custom_widget_CustomFooter_pad-top-20_hp49n_160","pad-top-30":"custom_widget_CustomFooter_pad-top-30_hp49n_164","pad-top-40":"custom_widget_CustomFooter_pad-top-40_hp49n_168","margin-left-20":"custom_widget_CustomFooter_margin-left-20_hp49n_174","margin-top-20":"custom_widget_CustomFooter_margin-top-20_hp49n_180","text-center":"custom_widget_CustomFooter_text-center_hp49n_186","text-right":"custom_widget_CustomFooter_text-right_hp49n_190","text-smaller":"custom_widget_CustomFooter_text-smaller_hp49n_194","text-small":"custom_widget_CustomFooter_text-small_hp49n_194","text-large":"custom_widget_CustomFooter_text-large_hp49n_199","footer-contact":"custom_widget_CustomFooter_footer-contact_hp49n_203","icon-gs-app":"custom_widget_CustomFooter_icon-gs-app_hp49n_221","gsi-icon-phone":"custom_widget_CustomFooter_gsi-icon-phone_hp49n_233","footer-link":"custom_widget_CustomFooter_footer-link_hp49n_245","footer-top-links":"custom_widget_CustomFooter_footer-top-links_hp49n_257","footer-top":"custom_widget_CustomFooter_footer-top_hp49n_257","footer-logo":"custom_widget_CustomFooter_footer-logo_hp49n_297","footer-list":"custom_widget_CustomFooter_footer-list_hp49n_305","dropup":"custom_widget_CustomFooter_dropup_hp49n_346","dropdown-menu":"custom_widget_CustomFooter_dropdown-menu_hp49n_359","footer-dropup-toggle":"custom_widget_CustomFooter_footer-dropup-toggle_hp49n_365","fa-angle-up":"custom_widget_CustomFooter_fa-angle-up_hp49n_370","footer-terms":"custom_widget_CustomFooter_footer-terms_hp49n_412","footer-terms-order-1":"custom_widget_CustomFooter_footer-terms-order-1_hp49n_431","footer-terms-order-2":"custom_widget_CustomFooter_footer-terms-order-2_hp49n_435","footer-bottom":"custom_widget_CustomFooter_footer-bottom_hp49n_441","footer-bottom-list-center":"custom_widget_CustomFooter_footer-bottom-list-center_hp49n_446","copyright":"custom_widget_CustomFooter_copyright_hp49n_495","gsFooterSocial":"custom_widget_CustomFooter_gsFooterSocial_hp49n_506","footerSocialItems":"custom_widget_CustomFooter_footerSocialItems_hp49n_509"}},"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1741694506000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1741694506000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeActionButtonWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeActionButtonWidget-1741694506000","value":{"defaultActionButtonTitle":"Start a Conversation","actionButton.grouphub.startDiscussion":"Start a Discussion","actionButton.title@board:FORUM":"Start a Discussion","actionButton.title@board:BLOG":"Create a Blog Post","actionButton.title@board:TKB":"Create an Article","actionButton.title@board:OCCASION":"Create an Event","actionButton.title@board:IDEA":"Suggest an Idea","joinGroupHub":"Join Group","join.successHeader":"Welcome","join.successMessage":"You are now a member of this group and are subscribed to updates.","errorMessage":"An unidentified problem occurred during the action you took. Please try again later.","errorHeader":"Error - Action Failed"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeInformationWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeInformationWidget-1741694506000","value":{"WidgetTitle":"About {title}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1741694506000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/community/FooterWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/FooterWidget-1741694506000","value":{"homeLink":"Community Home","topOfPage":"Top of Page","buildHash":"Build Hash:","buildNumber":"Build Number:","buildTime":"Build Time:","privacyPolicy":"Privacy Policy","helpLink":"Help"},"localOverride":false},"Category:category:RVTalk":{"__typename":"Category","id":"category:RVTalk","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"RVTalk","nodeType":"category","depth":1,"title":"Forums","shortTitle":"Forums"},"Forum:board:GetSupportAskQuestions":{"__typename":"Forum","id":"board:GetSupportAskQuestions","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:CommunityFeedback":{"__typename":"Forum","id":"board:CommunityFeedback","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:Announcements_Blog":{"__typename":"Blog","id":"board:Announcements_Blog","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Rank:rank:18":{"__typename":"Rank","id":"rank:18","position":32,"name":"Explorer III","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:398769":{"__typename":"User","id":"user:398769","uid":398769,"login":"Cherguin","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-12-31T12:48:10.593-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-4.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:18"},"messagesCount":17,"kudosGivenCount":14,"kudosReceivedCount":9,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:398769"},"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi0xNC01NjBpRjZEQTJBOEZFMzZFOUFBMw\"}":{"__typename":"AssociatedImage","url":"https://community.goodsam.com/t5/s/feyqc97479/images/bi0xNC01NjBpRjZEQTJBOEZFMzZFOUFBMw","mimeType":"image/png"},"Forum:board:TechnicalIssues":{"__typename":"Forum","id":"board:TechnicalIssues","entityType":"FORUM","displayId":"TechnicalIssues","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Technical Issues","shortTitle":"Technical Issues","parent":{"__ref":"Category:category:RVTalk"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi0xNC01NjBpRjZEQTJBOEZFMzZFOUFBMw\"}"},"description":"Having RV issues? Connect with others who have been in your shoes.","eventPath":"category:RVTalk/community:feyqc97479board:TechnicalIssues/"},"ForumTopicMessage:message:3636977":{"__typename":"ForumTopicMessage","uid":3636977,"subject":"House battery drain","id":"message:3636977","revisionNum":1,"repliesCount":8,"author":{"__ref":"User:user:398769"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalIssues"},"conversation":{"__ref":"Conversation:conversation:3636977"},"moderationData":{"__ref":"ModerationData:moderation_data:3636977"},"postTime":"2023-12-31T13:00:31.789-08:00","lastPublishTime":"2023-12-31T13:00:31.789-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":1540},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:TechnicalIssues/message:3636977"},"Conversation:conversation:3636977":{"__typename":"Conversation","id":"conversation:3636977","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3636977"},"lastPostingActivityTime":"2024-01-10T20:02:23.240-08:00","lastPostTime":"2024-01-10T20:02:23.240-08:00"},"ModerationData:moderation_data:3636977":{"__typename":"ModerationData","id":"moderation_data:3636977","status":"UNMODERATED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3636977":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3636977","relatedMessage":{"__ref":"ForumTopicMessage:message:3636977"}},"User:user:249":{"__typename":"User","id":"user:249","uid":249,"login":"sssooo","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2008-03-16T16:46:31.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-1.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"messagesCount":175,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:249"},"ForumTopicMessage:message:3588703":{"__typename":"ForumTopicMessage","uid":3588703,"subject":"Gen?","id":"message:3588703","revisionNum":1,"repliesCount":9,"author":{"__ref":"User:user:249"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Motorhomesforum-board"},"conversation":{"__ref":"Conversation:conversation:3588703"},"moderationData":{"__ref":"ModerationData:moderation_data:3588703"},"postTime":"2022-11-08T18:45:41.000-08:00","lastPublishTime":"2022-11-08T18:45:41.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2768},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:Motorhomes/category:TRAVELCENTER/community:feyqc97479board:Motorhomesforum-board/message:3588703"},"Conversation:conversation:3588703":{"__typename":"Conversation","id":"conversation:3588703","solved":false,"topic":{"__ref":"ForumTopicMessage:message:3588703"},"lastPostingActivityTime":"2023-02-07T03:06:14.000-08:00","lastPostTime":"2023-02-07T03:06:14.000-08:00"},"ModerationData:moderation_data:3588703":{"__typename":"ModerationData","id":"moderation_data:3588703","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3588703":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3588703","relatedMessage":{"__ref":"ForumTopicMessage:message:3588703"}},"Rank:rank:41":{"__typename":"Rank","id":"rank:41","position":33,"name":"Explorer II","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:108055":{"__typename":"User","id":"user:108055","uid":108055,"login":"mrad","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2007-08-23T12:56:43.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-12.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:41"},"messagesCount":292,"kudosGivenCount":0,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:108055"},"ForumTopicMessage:message:3376312":{"__typename":"ForumTopicMessage","uid":3376312,"subject":"Question on charging batteries with Gen","id":"message:3376312","revisionNum":1,"repliesCount":48,"author":{"__ref":"User:user:108055"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalIssues"},"conversation":{"__ref":"Conversation:conversation:3376312"},"moderationData":{"__ref":"ModerationData:moderation_data:3376312"},"postTime":"2020-10-02T12:03:47.000-07:00","lastPublishTime":"2020-10-02T12:03:47.000-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":8559},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:TechnicalIssues/message:3376312"},"Conversation:conversation:3376312":{"__typename":"Conversation","id":"conversation:3376312","solved":false,"topic":{"__ref":"ForumTopicMessage:message:3376312"},"lastPostingActivityTime":"2020-10-07T11:19:03.000-07:00","lastPostTime":"2020-10-07T11:19:03.000-07:00"},"ModerationData:moderation_data:3376312":{"__typename":"ModerationData","id":"moderation_data:3376312","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3376312":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3376312","relatedMessage":{"__ref":"ForumTopicMessage:message:3376312"}},"User:user:377613":{"__typename":"User","id":"user:377613","uid":377613,"login":"SCADAMAN29325","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-10-18T07:43:00.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-7.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:41"},"messagesCount":121,"kudosGivenCount":0,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:377613"},"ForumTopicMessage:message:3603409":{"__typename":"ForumTopicMessage","uid":3603409,"subject":"Need battery for house and gen starting?","id":"message:3603409","revisionNum":1,"repliesCount":17,"author":{"__ref":"User:user:377613"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Motorhomesforum-board"},"conversation":{"__ref":"Conversation:conversation:3603409"},"moderationData":{"__ref":"ModerationData:moderation_data:3603409"},"postTime":"2022-12-08T17:44:02.000-08:00","lastPublishTime":"2022-12-08T17:44:02.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":3442},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:Motorhomes/category:TRAVELCENTER/community:feyqc97479board:Motorhomesforum-board/message:3603409"},"Conversation:conversation:3603409":{"__typename":"Conversation","id":"conversation:3603409","solved":false,"topic":{"__ref":"ForumTopicMessage:message:3603409"},"lastPostingActivityTime":"2022-12-09T18:04:08.000-08:00","lastPostTime":"2022-12-09T18:04:08.000-08:00"},"ModerationData:moderation_data:3603409":{"__typename":"ModerationData","id":"moderation_data:3603409","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3603409":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3603409","relatedMessage":{"__ref":"ForumTopicMessage:message:3603409"}},"Rank:rank:39":{"__typename":"Rank","id":"rank:39","position":29,"name":"Nomad","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:2093":{"__typename":"User","id":"user:2093","uid":2093,"login":"Diamond_c","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-08-11T16:08:31.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:39"},"messagesCount":1025,"kudosGivenCount":3,"kudosReceivedCount":21,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:2093"},"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi02NC01NThpNzc1RUQ2QTdCRUQzRkI1NQ\"}":{"__typename":"AssociatedImage","url":"https://community.goodsam.com/t5/s/feyqc97479/images/bi02NC01NThpNzc1RUQ2QTdCRUQzRkI1NQ","mimeType":"image/png"},"Forum:board:Campgrounds":{"__typename":"Forum","id":"board:Campgrounds","entityType":"FORUM","displayId":"Campgrounds","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Campground 101","shortTitle":"Campground 101","parent":{"__ref":"Category:category:RVTalk"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi02NC01NThpNzc1RUQ2QTdCRUQzRkI1NQ\"}"},"description":"Recommendations, reviews, and the inside scoop from fellow travelers.","eventPath":"category:RVTalk/community:feyqc97479board:Campgrounds/"},"ForumTopicMessage:message:3595537":{"__typename":"ForumTopicMessage","uid":3595537,"subject":"Suggestions","id":"message:3595537","revisionNum":1,"repliesCount":16,"author":{"__ref":"User:user:2093"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Campgrounds"},"conversation":{"__ref":"Conversation:conversation:3595537"},"moderationData":{"__ref":"ModerationData:moderation_data:3595537"},"postTime":"2023-05-21T05:53:23.000-07:00","lastPublishTime":"2023-05-21T05:53:23.000-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":3862},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:Campgrounds/message:3595537"},"Conversation:conversation:3595537":{"__typename":"Conversation","id":"conversation:3595537","solved":false,"topic":{"__ref":"ForumTopicMessage:message:3595537"},"lastPostingActivityTime":"2023-05-28T12:11:15.000-07:00","lastPostTime":"2023-05-28T12:11:15.000-07:00"},"ModerationData:moderation_data:3595537":{"__typename":"ModerationData","id":"moderation_data:3595537","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3595537":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3595537","relatedMessage":{"__ref":"ForumTopicMessage:message:3595537"}},"QueryVariables:TopicReplyList:message:1691383:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:1691383:1","value":{"id":"message:1691383","first":10,"sorts":{"postTime":{"direction":"DESC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"DESC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/community/Navbar-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1741694506000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","rv-owners-link":"RV Owner Groups","groups-link":"Groups","migrated-link-7":"Good Sam Home ","community-feedback-link":"Community Feedback","migrated-link-8":"My Rewards","Common-community-feedback-link":"Community Feedback","migrated-link-1":"Groups","customer-support-link-1":"Customer Support","Common-announcements_blog-link":"Announcements","customer-support-link":"Resources","Common-get-support-ask-questions-link":"Customer Support","Common-external-link":"Events","migrated-link-0":"Forums","migrated-link-3":"Resources","announcements_blog-link":"Announcements","r-v-t-e-c-h-link":"Test ","Common-admin-mods-private-link":"Admin & Mods (Private)","fifth-wheelsforum-board-link":"Fifth Wheels Owners","events-link":"Events","external-link":"Good Sam Home"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1741694506000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1741694506000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1741694506000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1741694506000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1741694506000","value":{"title.login":"Sign In or Register","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In or Register"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1741694506000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1741694506000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1741694506000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1741694506000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1741694506000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/BuildInformation-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/BuildInformation-1741694506000","value":{"buildHash":"Build Hash: {buildHash}","buildNumber":"Build Number: {buildNumber}","buildTime":"Build Time: {buildTime}"},"localOverride":false},"CachedAsset:text:en_US-components/community/KhorosLogo-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/KhorosLogo-1741694506000","value":{"alt":"Powered By Khoros"},"localOverride":false},"ModerationData:moderation_data:1691385":{"__typename":"ModerationData","id":"moderation_data:1691385","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:1691385":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:307285"},"id":"message:1691385","revisionNum":1,"uid":1691385,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:Motorhomesforum-board"},"parent":{"__ref":"ForumTopicMessage:message:1691383"},"conversation":{"__ref":"Conversation:conversation:1691383"},"subject":"Re: Gen Battery Suggestions","moderationData":{"__ref":"ModerationData:moderation_data:1691385"},"body":"
JimFromJersey wrote:
Your genny doesn't \"take\" batteries, per se. It's starts via either the engine-start battery (often called the 'chassis' battery) or the auxiliary batteries (often called the 'coach' or 'house' batteries). It should, when running, charge the house batteries, and POSSIBLY, but not probably, the engine battery. In most cases, the engine/starting battery is charged by the alternator only, when the engine is running. Once you start the genny, your converter panel should, in a second or two, switch over the current so that your 12v and 120v systems are powered by the generator.
Interstate makes good batteries. Most people have a 'favorite' battery that may or may not be based on quality. Don't go cheap, though. Keep them charged.
Here's a hint - in most cases, when your MH is plugged into 120v \"shore\" power, your house batts are usually kept charged by your converter, but NOT your starting battery. You can buy a cheap diverter for about $20 that steals a little bit of the juice going into your house batteries, and keeps your engine battery charged up at the same time. Highly recommended. BestConverters.com, look for \"trick-L start\" or something like that.
THANK YOU Jim! I appreciate the input and tips on the diverter!","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-03-27T13:19:28.000-07:00","lastPublishTime":"2015-03-27T13:19:28.000-07:00","metrics":{"__typename":"MessageMetrics","views":108},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:Motorhomes/category:TRAVELCENTER/community:feyqc97479board:Motorhomesforum-board/message:1691383/message:1691385","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"readOnly":false,"editFrozen":false,"body@stringLength":"1319","rawBody":"
THANK YOU Jim! I appreciate the input and tips on the diverter!","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:1691385_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"User:user:287129":{"__typename":"User","id":"user:287129","uid":287129,"login":"JimFromJersey","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2010-09-15T18:13:41.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-10.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:287129"},"ModerationData:moderation_data:1691384":{"__typename":"ModerationData","id":"moderation_data:1691384","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:1691384":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:287129"},"id":"message:1691384","revisionNum":1,"uid":1691384,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:Motorhomesforum-board"},"parent":{"__ref":"ForumTopicMessage:message:1691383"},"conversation":{"__ref":"Conversation:conversation:1691383"},"subject":"Re: Gen Battery Suggestions","moderationData":{"__ref":"ModerationData:moderation_data:1691384"},"body":"Your genny doesn't \"take\" batteries, per se. It's starts via either the engine-start battery (often called the 'chassis' battery) or the auxiliary batteries (often called the 'coach' or 'house' batteries). It should, when running, charge the house batteries, and POSSIBLY, but not probably, the engine battery. In most cases, the engine/starting battery is charged by the alternator only, when the engine is running. Once you start the genny, your converter panel should, in a second or two, switch over the current so that your 12v and 120v systems are powered by the generator.
Here's a hint - in most cases, when your MH is plugged into 120v \"shore\" power, your house batts are usually kept charged by your converter, but NOT your starting battery. You can buy a cheap diverter for about $20 that steals a little bit of the juice going into your house batteries, and keeps your engine battery charged up at the same time. Highly recommended. BestConverters.com, look for \"trick-L start\" or something like that.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2015-03-27T12:19:39.000-07:00","lastPublishTime":"2015-03-27T12:19:39.000-07:00","metrics":{"__typename":"MessageMetrics","views":108},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:Motorhomes/category:TRAVELCENTER/community:feyqc97479board:Motorhomesforum-board/message:1691383/message:1691384","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"readOnly":false,"editFrozen":false,"body@stringLength":"1192","rawBody":"Your genny doesn't \"take\" batteries, per se. It's starts via either the engine-start battery (often called the 'chassis' battery) or the auxiliary batteries (often called the 'coach' or 'house' batteries). It should, when running, charge the house batteries, and POSSIBLY, but not probably, the engine battery. In most cases, the engine/starting battery is charged by the alternator only, when the engine is running. Once you start the genny, your converter panel should, in a second or two, switch over the current so that your 12v and 120v systems are powered by the generator.
Here's a hint - in most cases, when your MH is plugged into 120v \"shore\" power, your house batts are usually kept charged by your converter, but NOT your starting battery. You can buy a cheap diverter for about $20 that steals a little bit of the juice going into your house batteries, and keeps your engine battery charged up at the same time. Highly recommended. BestConverters.com, look for \"trick-L start\" or something like that.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:1691384_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1741694506000","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1741694506000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1741694506000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1741694506000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1741694506000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1741694506000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1741694506000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1741694506000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1741694506000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1741694506000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1741694506000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000","value":{"title":"{nodeTitle} ","creationDate":"Created: {creationDate}","ownedBy":"Owned by: {owners}{text}","showOwnerListText":", and {ownersCount} more","unreadCount":"{count} unread","nodeViewDrawerBtn":"Node view drawer for {place}","drawerActionTooltip":"Show category children"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1741694506000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"Revision:revision:1691385_1":{"__typename":"Revision","id":"revision:1691385_1","lastEditTime":"2015-03-27T13:19:28.000-07:00"},"Revision:revision:1691384_1":{"__typename":"Revision","id":"revision:1691384_1","lastEditTime":"2015-03-27T12:19:39.000-07:00"},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1741694506000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeTopicsCount-1741694506000","value":{"topicCount":"{count}","topicCountWithNeutralLabel@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","topicCountWithNeutralLabel":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:FORUM":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:BLOG":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:CONTEST":"{count, plural, one{# Entry} other{# Entries}}","topicCount@board:GROUP":"{count, plural, one{# Topic} other{# Topics}}","topicCount@board:IDEA":"{count, plural, one{# Idea} other{# Ideas}}","topicCount@board:QANDA":"{count, plural, one{# Question} other{# Questions}}","topicCount@board:TKB":"{count, plural, one{# Article} other{# Articles}}","topicCount@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","title":"{count, plural,one { Post} other{ Posts}}"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLatestActivityTime-1741694506000","value":{"title":"Latest Activity: {latestActivityTime}","updatedAt":"Updated {latestActivityTime}","noActivity":"No activity yet"},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1741694506000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"motorhomesforum-board","messageSubject":"gen-battery-suggestions","messageId":"1691383"},"buildId":"q_bLpq2mflH0BeZigxpj6","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"campingworld","openTelemetryServiceVersion":"25.2.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/nodes/NodeActionButtonWidget/NodeActionButtonWidget.tsx","./components/nodes/NodeInformationWidget/NodeInformationWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/community/FooterWidget/FooterWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/ThreadedReplyList/ThreadedReplyList.tsx","./components/community/FooterWidgetHelpLink/FooterWidgetHelpLink.tsx","./components/community/KhorosLogo/KhorosLogo.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/nodes/NodeView/NodeView.tsx","./components/nodes/NodeView/NodeViewCard/NodeViewCard.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx"],"appGip":true,"scriptLoader":[]}
