โJun-16-2019 07:30 PM
โJun-21-2019 11:18 AM
larry barnhart wrote:hotjag1 wrote:
Generac service center did a lot of testing and determined that when the GEN was under heavy load (AC) the voltage regulator would get warm and the voltage would increase. When that happened an internal resetting circuit breaker would open and cut power output from the GEN.
The voltage regulator under lighter loads such as coffee maker or microwave wasn't drawing enough power to heat up the voltage regulator as this only happened with the AC on. They replaced the voltage regulator and ran the AC for over an hour and everything worked as designed. $100 labor and $100 regulator and so far, so good.
Where did you get the repair done?
chevman
โJun-21-2019 09:47 AM
โJun-21-2019 08:33 AM
โJun-21-2019 07:08 AM
โJun-21-2019 04:09 AM
โJun-20-2019 09:35 PM
โJun-17-2019 06:31 PM
D.E.Bishop wrote:
From past experience I can tell you that if the brushes are not in contact with the slip rings your generator will shut down.
My suggestion is to first check the circuit breakers on the genny.
โJun-17-2019 05:48 PM
โJun-17-2019 11:47 AM
โJun-17-2019 10:09 AM
way2roll wrote:
Since it continues to run, it sounds more like the ATS than the overheat shutdown. Does anything else other than the AC continue to run? Is there a code on the panel?
โJun-17-2019 05:52 AM
โJun-17-2019 05:14 AM
โJun-16-2019 09:34 PM
akrv wrote:
Went to a rally in Cashmere WA it was a 100 degrees the whole time. Every one that had 5500 generacs would shutdown when the AC was running and air temp got over 98 degrees. Turns out there is a high temp oil switch maybe yours has same problem. Almost all the units were 98-2004
โJun-16-2019 08:56 PM
