loneryder
Jul 09, 2015Explorer
path1 wrote:
If yours is like mine.....
Look real close at switch. See bottom at lower left where it says "stop/prime"
If genny is not running, push in "stop/prime" switch and you should here a little pump, when it makes a different noise, let go. Then push top of switch and starter should engage and start the genny.
Thanks all. My button is a small toggle switch and there is no "prime" printed on it. I held it in on stop and the light didn't come on. I will get the manual out and will try priming method also.
