Gambler2344
Sep 12, 2014Explorer
Generator possibly not getting fuel
I am new to RVing as I just purchased a 1985 Coachmen. I checked everything out and it was working fine including the generator. I had the Rv serviced for an exhaust leak and oil change. I now started to come home and I origianlly was using the front gas tank as I drove it around a few days before I took it in. I was coming home and I noticed it was on the rear take so I switched it to the front and in a few minutes the rv shut off so I switched it back to the rear and it came back on and I drove it home. I know when I bought it starting out it did hesitate and would sometimes shut off and you had to feather the gas pedal to get it running. Once going it was fine. Now it runs perfect on the rear tank. To my other problem now the generator will not start and it was working fine before I took it in. My question is if the fuel pump is out on the front tank does it effect the generator getting gas at all? So my two issues that I need help on are when I use the front tank the RV shuts down when it runs out of fuel and now my generator isn't working. Does the generator pull gas from tank 1? Any help would be greatly appreciated. Thanks
