I had a similar issue right after purchasing my practically new Roadtrek. I pushed Test on the GFCI receptacle breaker and could not get it to go back on.
I called Roadtrek this morning. The trick to resetting the GFCI receptacle breaker is to push it first **ALL THE WAY OFF ** then push it on. It takes some * muscle ( for a woman ) because I thought it was off, but when I really pushed it off , it then was truly in the off position and then it went back on - without difficulty and - without needing to be connected to shore power. And all outlets work fine.
