Got a hole in my shower tub
T18skyguy
I just discovered a hole in my shower tub. I have a 22 foot class C, and we use the tub for storage not showering. Something tipped over and did the damage. It's not very big, just a slit that looks like it was made with your thumbnail, but it is pierced. My local RV guy said the tub is probably either ABS or Polyethylene. It has a very smooth yellow coating on the tub. Getting to it from the back is impossible. If anyone has any ideas on how I might repair this I would appreciate it very much. Thanks in advance
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. Between rigs right now.. Wife and daughter. Four cats which we must obey.
9 REPLIES 9
_1Flyboy
.. . . If you do not worry about appearance, Eternabond over the repair will also work. . .
Harvey51
I tried ABS solvent from the hardware store on my curling broom head when it cracked. The solvent made it stronger than original. It melts the plastic together. Will leave a black appearance. And will only work on ABS plastic.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
T18skyguy
Thank you guys for all your excellent suggestions. I think I had about 8 options when I looked at it all. I ended up using 3M Marine adhesive/sealant which the boating crowd gave rave reviews. It seems to be setting up nicely so I'm keeping my finger crossed. Thanks to all.
garyhaupt
Guess my question is...what's the vintage of the C? If you are into the older ones, then the re-sale won't be much harmed. If it's newer? If you figure on selling it anytime soon? get it fixed properly. Yes..a new pan.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
ScottG
Go to a marine supply store and buy one of the patching products they have for the hull of boats.
ksg5000
Google "rv shower pan" - they cost about $150.
Kevin
DutchmenSport
Replacing the tub will be an adventure in futility! Campers are built from the inside out. Tubs and showers are usually the first thing laid on the floor and then everything is built around it, opposite like you'd do in your house. Here's a photo of a Denali 5er from a tour we took of the Dutchmen factory in 2006. The manufacturing methods have not changed. Maybe this photo will give you an idea of how the tub is installed.
But really, if you patch it with one of the suggestions above and it works, it will be much easier and cheaper.
Valkyriebush
I used JB water weld putty on a crack in mine with no drilling five years ago. Mush some up, spread over the crack, let dry. Done. Color a little off, no big deal to me.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
mobilefleet
first drill a very small hole at both ends of the crack to prevent further spreading. Then go to a home center and get a fiberglass tub repair kit which is basically a white epoxy mix that you can apply to the area to repair
