Sheafaugl's avatar
Sheafaugl
Gray tank size for 2011 four winds hurricane 31D.
I have a 2011 four winds hurricane 31d that I bought used and was told that the gray tank is cracked. It is mounted above the gas tank. I am having a hard time finding a replacement to order of even the dimensions to order a new one. Anyone can help? I am at a loss. Thank you kindly
  • We had a pinhole leak in the black tank. Took it out and had it plastic welded. No problems since. This was in a 2005 Hurricane 31K
  • there shops that can weld plastic ,find a shop close to you and call them. years back I watched a welder use a plastic heat gun and plastic rod ,excellant out come.
