Water was leaking from the vicinity of the holding tanks when I got home from taking the RV to the emissions test place. Upon investigation I found the leak was coming from the grey water tank.
There are two "clips" on the drivers side of the tank that attach it to the side of the RV, the rear clip was not connected to the tank. The front clip was attached, but the tank itself was broken with a hole in it at that spot. The tank is actually resting some on the middle of the RV (or whatever is there). And the tank is bulged out a little in the bottom. Not sure if the bottom bulge is the cause of the clip issue, or result of it.
Anyways, obviously it has to be replaced. And I'll be using the search function momentarily on the subject. But it's late (for me) and I need to get to bed soon.
So, any guidance for doing this? Should I just pay a shop to do it? We're taking it out of town in less than 2 weeks. :(...
Matt
2007 Keystone Cougar 289BHS 5th wheel
1991 F350 7.3 Diesel Crew Cab
1998 32' Georgie Boy Cruise Master (1st RV, got 4/2013) - SOLD 5/2016
