Jayco-noslide's avatar
Jul 29, 2019
Handling/steering.
Frustrated with the way our 2003 30 ft. Class C; Ford E-450 chassis drives(65000 miles). We flat tow a Ford Focus. With little wind on a smooth highway I would rate it a C for the steering, handling feel. My Ford Focus and a 2007 Chevy half-ton I had would rate an A or B in comparison. On narrow winding roads or with a wind it would be an F. Dangerous and tiring. The MH wanders, requires constant steering input and feels like there's lots of play(moving the steering wheel with no response). I've tried having some sort of front shock devise added, and found the front wheels were poorly balanced and over inflated by 15 lbs. Seemed better at 1st but not really. Been advised it might be the long overhang behind rear axle. Don't know where to go for a solution. If the steering gear needs replaced, how much$$ ? I'm thinking nothing will do it until the slack/play is removed??
Also wondering how close to "normal" mine is? Must be thousands of these on the road. HELP.
