bobndot
Aug 18, 2019Explorer II
pushtoy 2 wrote:bobndot wrote:
Use a long #2 Phillips screwdriver . There is an access hole above the headlight with a long downward reach to the adjuster on the back of the light housing. The adjuster is very easy to turn with no or little resistance.
thank you for your reply have to look for that
Locate things during daylight hours and use a narrow beam flashlight to look about 12-14" down the nickel size hole to view the adjuster on the back of the light housing. Once you done that, its a lot easier to do the adjustment in the dark.
My adjuster is so loose, it didn't seem like it was doing anything...felt like it was broken, just spinning.
If you watch the headlight beam against a wall , you will actually see the beam move up and down, depending on clockwise or counter clockwise adjustment.
38,708 PostsLatest Activity: Mar 06, 2025
