Heating element?
sssooo
I have a 2018 Fleetwood Bounder need to change the water electric heating element where do
I get to the element?
I donโ€™t need to know where to get one I canโ€™t see where it is on my heater? It is not in the front of the heater!
I canโ€™t see it on the inside of Mh?
20 REPLIES 20
sssooo
I am NOT going to do this I am taking it to shop!
dougrainer
ALL Atwood/Dometic built in the last 25 years the element is in the back. As I stated, Fleetwood, you have to remove the Water heater to replace the element. The OP pics show the bottom outside Fleetwood access plate. You remove the screws and cut the sealant to access the BACK of the water Heater. This gives you access to the Plumbing lines and the 120 power cable. "most" Fleetwoods the Power 120 cable is long enough to pull out the water heater and place on a short stand/table beside the sidewall of the motorhome. Remember, The Heat element is LONG. So, that is why you have to pull the water heater. IT IS EASIER TO WORK ON THE BACK AFTER BEING PULLED. Trying to pull the water heater out partially and working from underneath will just increase your profanity yelling. Doug
Bruce_Brown
Moderator
Moderator
I just found a diagram, it's on the back.
Click to see diagram.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
sssooo
shastagary wrote:
Replacing Water Heater Element on Atwood GC10A-4E Water Heater
This photo shows where that red arrow is pointing and there is not a element there?
sssooo
It looks like I am going to get on my back and look at it myself my wife usually finds me on my back is after I fall down.
This time she finds me on my back she might just leave me there but I like to Bo this stuff myself you guys know what I mean!
enblethen
Etrailer photo is pointing toward the drain plug.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sssooo
Now I am confused one says it is in the front other says it is in the back?
I think it is in the back
I looked inside for access to the back no access anywhere?
enblethen
This shows where water heater 120 volt element is located.
Bud
USAF Retired
Pace Arrow
wa8yxm
Ah where is it on the heater.. Two ways to find it.
Atwood or whatever replaced that label on the 'Backside" (inside the rv) there is a black box.. it's basically under and perhaps slightly above that box under the insulating foam
Suburban I suspect much the same place. but follow the 120 volt wires. That easy.
Horsedoc
https://www.amazon.com/ATWOOD-ELEMENT-GC6AA-10E-GC10A-4E-GCH10A-4E/dp/B0843CSKMP/ref=asc_df_B0843CSKMP?tag=bingshoppinga-20&linkCode=df0&hvadid=79852142364588&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583451673471548&psc=1
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
sssooo
The top pic is under the Mh the bottom of the heater
BB_TX
sssooo wrote:
How do I post photos? I saw a video that showed a actress in the bottom of heater I think I have one I have a photo of bottom and it looks like a actcess boor in photo?
I a m 72 and I canโ€™t get down!
Photo posting info
sssooo
How do I post photos? I saw a video that showed an actress in the bottom of heater I think I have one I have a photo of bottom and it looks like a actcess door in photo?
