stugpanzer
Jun 04, 2015Explorer
Heavy Duty Jack Pads
I just finished my new homemade heavy duty jack pads.
I laminated three layers of 3/4" plywood, screwed and glued. I then primed the wood and painted them with safety yellow oil based paint. I wanted them to be easily seen so I wouldn't forget about them! I glued Rubber Horse Mat on the top and bottom using E6000 glue. (You can read about the horse mat here: Horse Mat Pads). I countersunk 1/4" galvanized lag bolts into the rubber (just in case the glue gives) and finally I put handles on.
These things are very heavy duty and can be used on any surface. Each one weighs in at about 15lbs.
I will be testing them this weekend on a trip we are taking!
