Sir_Traveller
Dec 30, 2020Explorer
house battery leaking
Hello everyone…
I have a 2003 Ford F-53 RV
I have noticed a small leak in one of the house batteries ( I have two 12 volt batteries)
To give you a better history, both batteries are exactly 3 years old, I have driven the RV for 3000 miles on the first year, and since then it has been hooked up for 6 months then another 6 months in storage, I check the batteries and add distilled water every few months, there is no corrosion or any other issues, the RV has a built-in charger that keeps them charged when I am hooked up to shore power.
The RV has been in storage from March till November, last time I added distilled water was in March… when I operated the RV in November ( the chassis battery had died so I had to jump start it ) I noticed that leak or overflow on side of the caps of the second battery… I thought it was because I drove the RV on bumpy road from storage to the spot… last week I changed the chassis battery, turned the RV on for few minutes then changed the oil… then I noticed that small leak again… the panel light indicators ( with the 4 dot lights ) show the batteries are fully charged so I ruled out the issues with charging, also cannot be too much distilled water since I haven’t added any since March… the leak seems very light / small, barely wet area on the top next to the caps… so what could that be acid or water? And what are the possible causes based on the history of the RV I mentioned above ?
Thank you all for taking the time to read my post
