- Sunnyjim245ExplorerOK, got the instrument panel out but now I have a problem. The screws that hold it in were 8-32 which are too small to thread into the panel, 10-32 are too large. M4 is too small and M5x80 will only go in about a turn. What is this? Thanks!
- TexasHExplorerMy 2002 Southwind (also by Fleetwood) has velcro (yes, I said VELCRO!)across the top of the dash above the instrument cluster where it joins the flat top of the dash, and two screws at the bottom slides. Work your finger under the velcro to pull it apart and the front of the dash will rotate down on the two screws far enough to get the cluster out.
By the way, I replaced the velcro with new industrial strength velcro and it quietened down the squeaks and groans that come from all Fleetwood dashes. - mike_brezExplorer
Or if you like power tools - Sunnyjim245ExplorerTried that; no luck. From what I have read instrument panel failure is not uncommon, I am surprised that no one here has removed one. That's good!
- midnightsadieExplorer IImight check U tube, could be your lucky day.
About Motorhome Group
38,707 PostsLatest Activity: Feb 13, 2025
