- Dusty_RExplorerIt's missing a crank & dial, that cranks up the antenna and turns it, it's directional, if I'm remembering right.
- This manual should help.
Winegard sensar - IAMICHABODExplorer II
It looks like it is missing These parts to move it around and the Handle to crank it up - CA_TravelerExplorer IIIWith the missing parts, consider possible additional issues.
- Missing spring!
enblethen wrote:
Missing spring!
does it come with the spring?
Answer:
Yes, the spring is included in the RP-6200 kit.
By Winegard Company Manufacturer on September 27, 2017
Yes it should be included in the kit
By Tom Hackert on September 26, 2017
Hi yes it does. Thank you
By Carl's RV Parts & Service Seller on September 26, 2017
Yes it does.
By Amazon Customer on September 27, 2017
In kit referenced above. - SCADAMAN29325Explorer IIThank you again!!!
- bukhrnExplorer IIIHave you been on the roof? Is there even an antenna up there?
- bobndotExplorer IIWould replacing it using a new King antenna be a better antenna ? Anybody know ?
If deciding on going the solar route:
Replacing larger , weathered , old tech antenna with a smaller head new digital model which would leave more roof space for solar panels. The newer tech King might also draw less 12v power from ur coach battery bank. Something to consider , especially if boondocking is your plan.
There is a video of a direct swap , installing a new King.
Replacing old tv antenna with a King - CA_TravelerExplorer III
bukhrn wrote:
Good one - LOL
About Motorhome Group
38,705 PostsLatest Activity: Jan 14, 2025
