Kendas
Jul 23, 2008Explorer
Leeann wrote:Damned Leeann, you beat me to it. :W
F44CD7V0
F4=MB400
4=Hi Line Wagon or MB4 Hi Line
C=GVW 10001 lbs
D=440-1
7=1977
V=Warren assembly plant
0=digit #1 of the assembly number
Dodge makes the chassis and has to give it an identity, hence the VIN number. Fleetwood has to give it an identity and uses a numbering system all their own, hence the G07 number.
There is some doubt about the engine... I've been told that Dodge never put the -1 HP engine in the RV chassis, but every thing I've found so far (without checking the lower right block) says they did.
The only sure way is to look at the plate on the front right side of the block just below where the heads sit. This is a PIA if the engine is in the chassis.
Ken
