โAug-15-2004 01:22 AM
โFeb-02-2015 05:15 PM
โFeb-01-2015 12:39 PM
JDMopar wrote:
The easiest way to check the timing chain is to pull the fuel pump off of it. It's on the passenger side of the timing cover, right under the alternator. You can stick your finger in the hole, and see how slack the chain is. It will probably scare you when you find out how sloppy it is....lol. Your water pump may be leaking out the weep hole in the bottom of the shaft housing. If you change it yourself, be careful not to break the bolts that are to the far left and right of the water pump. They go all the way thru the timing cover, and into water jackets in the block. They are bad to rust up and break when you attempt to remove them. Work them back and forth as you remove them, and have patience. Buy an Edelbrock double row timing chain from Summit or Jegs to replace the crappy plastic covered gears on the factory chain. You won't hear a difference in noise. Be sure to drain the oil, and make a wire hook to reach up thru the drain hole in the oil pan, and dig all the remnants of the plastic gear out before refilling it with oil. Hope this helps, and good luck.
โFeb-01-2015 06:54 AM
โJan-23-2015 03:57 AM
โJan-22-2015 07:25 PM
โDec-05-2014 05:22 AM
rehoppe wrote:
Also, if you are at that kind of mileage, put a timing light on it and check the timing chain. My 76 had plastic over metal gears, the nylon came off the metal. Ran a lot better after I put a new timing set in it.
rehoppe wrote:
Check the chain BEfore you do the pump!!!!! since you're going to be in there. lol
Don't ask me why I remembered to tell you this.....
โDec-04-2014 03:56 PM
Mykedynamics wrote:
Have any of you 360 owners developed a coolant leak of your water pump or timing cover? I have been in some serious temp fluctuation and have started to drip a little in morning when cold..any thoughts...should address immediately? Not losing much coolant but don't want something to explode while driving
โDec-04-2014 09:55 AM
โNov-24-2014 09:22 AM
โNov-23-2014 08:15 PM
โNov-22-2014 11:17 AM
โNov-22-2014 10:37 AM
โNov-22-2014 09:26 AM
โOct-28-2014 08:08 PM
โOct-28-2014 04:08 PM
