โJul-08-2014 08:14 AM
โJul-09-2014 08:40 AM
โJul-08-2014 02:33 PM
bshpilot wrote:
Start w/ the least - you can always (slowly) turn it up....
stay away from any seams, joints, seals or other objects where water could enter.
โJul-08-2014 02:32 PM
mtrumpet wrote:
I use mine (1750 psi power washer) on mine all the time. Cleans much better then just washing than a garden hose.
HOWEVER, on mine, I don't have a pressure setting. My pressure is determined by which (removable) nozzle (amount of fan out) that I use in the end of the wand. I use the widest angle fan nozzle (considered the lowest pressure). I seldom get the wand closer than about 18" from the surface. You still have to always be very careful of where you point it at all times.
โJul-08-2014 02:29 PM
wa8yxm wrote:tderonne wrote:
You'll have to have the pressure washer 4 corner weighed and consult the manufacture's pressure charts.....
...couldn't resist, sorry.
Thank you... Needed a laugh.
Best advice to the O/P is to use whatever pressure you like and adjust your DISTANCE.. Those high pressure jobs will dig a ditch right through concrete at 1". but at 6' they may not even dampen you.
The pressure drops very fast as you back off the target.
โJul-08-2014 01:37 PM
โJul-08-2014 12:28 PM
โJul-08-2014 10:14 AM
Sully2 wrote:
Got a pressure sprayer here and a coach that has some REALLY filthy spots. I know that HI is WAAAAYYYY too much pressure to use but what psi settings can / would a guy use.
Bad locations are the roof roll over where it blends into sidewalls. Got me stumped??
โJul-08-2014 10:10 AM
โJul-08-2014 10:04 AM
โJul-08-2014 09:37 AM
โJul-08-2014 09:02 AM
โJul-08-2014 08:35 AM
