- bigred1cavExplorertHANK YOU, NOW HOW DO i GET IT TO DISPLAY?
IAMICHABOD wrote:
Create your Visited States Map.
1. Go to http://www.epgsoft.com/VisitedStatesMap/.
2. Select the states you have visited.
3. Set the map size to small, since RV.net forums limit images sizes to 100 pixels in height.
4. Set the file format to GIF or JPEG (JPEG files look better).
5. Create the map.
6. Once it appears, save it by right clicking on it and selecting Save Picture As... (remember where you save it).
Add the map to your signature.
6. Go to the RV.net forum.
7. Login if you aren't already (click Login Here at the top of the page).
7. Click on My Forums at the top of the page.
8. Click on My Preferences.
9. Go to the line titled Signature Picture and click on Browse...
10. Select the file containing the map that you saved in step 6 and click Open.
11. Click on Submit Changes at the bottom of the page. - IAMICHABODExplorer IICreate your Visited States Map.
5. Create the map.
11. Click on Submit Changes at the bottom of the page. - bigred1cavExplorer
Bill.Satellite wrote:
The same way you posted the one that is there now.
Obviously, I have forgotten how I did that. - Bill_SatelliteExplorer IIThe same way you posted the one that is there now.
IIRC, you just go back to step one and create a new map with the new States added and then replace the one in your current signature.
Yep, you cannot add states to an old map but must create a new map with ALL the desired states on it.
Thanks, how do I place the map on my page? - accsysExplorer
Yep, you cannot add states to an old map but must create a new map with ALL the desired states on it. - Bill_SatelliteExplorer IIIIRC, you just go back to step one and create a new map with the new States added and then replace the one in your current signature.
- IAMICHABODExplorer IITry THIS found it in This Thread there may be others in this one.
About Motorhome Group
38,709 PostsLatest Activity: Mar 09, 2025
