Mousekiller's avatar
Mousekiller
HWH Leveling system
Hi all, I'm wondering if anyone has an opinion on HWH levelers? My motorhome did not have any levelers when I bought it. I now have enough money to by the HWH system. I'd prefer to get the Bigfoot but I just don't have the money for that system. My motorhome is 34' and after having to haul blocks and bottle jacks around last year and spending 40 minutes to level the darn thing I figured it was time to get a proper leveling system put on it. I can get the whole system installed for ~ 4000.00... so any input would be helpful. Thanks
  • Make sure to go for the auto level system, instead of the basic, much nicer,
  • I much prefer my HWH system compared to the LCI (Lippert) in my previous coach. I had serious problems with that Lippert system. The HWH has been trouble free !
    Hhg
  • I do not like the Bigfoot system as they have a pump for each jack and are POWER DOWN AND POWER UP. Manual retraction is a pain if the pump malfunctions. HWH/PG are spring retract and have just one pump. If the Pump/electrical control malfunctions, you can manually retract by opening the solenoid for each jack. HWH has been in the jack business longer than anyone else and have the BEST systems, in my opinion. I have serviced and installed then for over 25 years and they are the best. Doug
  • Good morning
    My 32' class c has HWH automatic levelers and they've worked perfectly for years. By all means put on a set of levelers it makes everything better. Pull in, get her parked where you want her, chock the wheels and push the auto button. Your done. I've never had any problems with them or even had to add oil. My rig uses the HWH 625 auto leveler system.
    Dave
  • We are on our third class A with HWH and other than replacing two broken return springs over the years, no issues.
