Thanks for the input. PROBLEM SOLVED. I think the battery was too low to send energy to the switch telling whatever to shut down the engine. Having run about an hour may have charged up the batteries enough for that message to be sent with a command to shut down. Anyway I pulled the guts out of the ignition switch (1999 chevy truck) and put a screwdriver inside and turned the switch off. Stopped. Now I had tried that earlier but it didn't work which makes me think the batteries were too low to send the correct command"
Never got to the helpful ideas you sent but that was my next move. I'm sure one of those ideas would have worked.. This forum has provided me with a lot of help and I am thankful to you members for that. Arnold
