lre01 wrote:
Good frame shop should be able to advise you if they can increase the towing ability and certify it. I never did it on a MH, but on class 8 trucks we had axles added, frames beefed up to carry point loads and hitches installed to pull 20 tons, all with a new door tag to certify the modifications made.
Well, except that the frame is not the only factor effecting tow-rating. Two different P30's might have different brakes, cooling systems, suspension systems, etc.
As noted above, a large number of factors can effect the tow rating
