alkillion
May 13, 2014Explorer
Intermitent 'Low Voltage' indicator on dash readout
Question for you diesel owners.
I have a 2014 Winnebago Forza on Freightliner chassis. It has an electronic readout on the dash. We happen to be in Colorado right now (meaning cold). When I started the coach the other day I got a 'low voltage' message on the dash display. The message would come on for maybe 10 seconds, then go off for maybe 10 seconds, then come back on again.
This went on for several minutes, then stopped. I could see the volt meter and when the message came on, the meter was down to about 9v. Normal is about 13v.
Was thinking maybe I had a bad battery, so I ask the folks at a repair shop. They said it was a "grid heater" that is used to warm the intake air until the engine gets up to temp. Batteries were ok.
The question is, does this jive with what you know?
Thanks for your knowledge.
