joraz
Sep 21, 2015Explorer
Intermittent Furnace Issue
It's an Atwood 8516-III manufactured in 1994.
The furnace runs fine with normal noise and air flow but sometimes the fan will run but the thing won't ignite. This is intermittent - may be two weeks and many firings between failures. Once it fails, it sometimes works after three or four tries but last time wouldn't light after many attempts. Working fine now.
I figured the sail switch and limiter are good because it works almost all the time. Is that a correct assumption? To fix it I installed a Dinosaur board. Of course, it worked great until the old problem resurfaced.
I've cleaned all the connections I can get to and don't see any obstructions anywhere (have blown out with air).
This morning I had what I think is an unrelated problem - thermostat failure. Flipped the switch and nothing happened. Checked for current - was good. Swapped out the thermostat with my other one and it works fine. Is it possible a bad thermostat could be the cause of the original problem (don't think so)? It's an after market Luxpro.
Anyhow, thanks for any input.
jor
jor
