werni9's avatar
werni9
Inverter/Charger (modified or pure)
I was told by 4 separate Frigidaire Customer Service reps, that Frigidaire's warranty is GOOD for residential refrigerators going into a motor home. Home Depot says the same about their 3 and 5 year extended warranties. Question # 1....I've heard in here that Frigidaire does not warrant frigs in RV's. Thoughts??? Question # 2...The Frigidaire I am looking at, is 12 c.f. no frills. No LED's. Just turn knobs to set temp. What about my Xantrex 458 "Modified Sign" Inverter/Charger. Read in here, that should be a "pure sign" inverter or it messes with the electronics in the frig. FYI...the Xantrex 458 is a combo Inverter/Charger. 2000 WATT ..It is ON all the time, while we are plugged in. Pure or Modified ??? Warranty GOOD ??? Thank you.
  • If budget allows, always go full sine. This is my rule of thumb. You won't be as limited.
  • wa8yxm's avatar
    wa8yxm
    MSW inverters are nortorious for generating RFI (Radio frequency interference) this may wipe out your TELEVISION and affect Audio systems as well..
    PSW inverters.. Dead silent at RF levels, NO problems with Television or Audio.
    NOTE: The Radio/Audio/Television device affected does not need to be connected, Does not even need to be in your RV.
  • I put a Frigidaire in last July. The first day using a MSW inverter it burned out the evaporator fan circuitry. I replaced it the next day, the new fan didn't have the same circuitry and works fine on MSW. I also installed a 1000W SW inverter dedicated to the refrigerator.
    The warranty is relatively useless. Frigidaire assigns a repair shop to the job & they come to look see a few days later. Once they decide the part is bad they go back to the shop & order the part from Frigidaire. A week or so later the part arrives, the shop calls to schedule the install a few days later. That schedule doesn't work when you are travelling & really never works. Even if the parts warehouse has the part the warranty requires it to be ordered from Frigidaire.
    That program was unacceptable so I bought the part at Appliance Parts Depot, installed it myself and continued on my travels.
  • Ivylog's avatar
    Ivylog
    The no frills one should work fine on MSW but you loose about 15% efficiency over running it with a PSW. If you do not boondock then this extra energy use is not a big deal. In hindsight you probably should have gone PSW when you replaced. A 500W PSW like smkettner suggested is another option.
    Not sure why you are going so small when a Whirlpool 21 will come real close to fitting.
  • Given what you want to do I would go with the full sine wave inverter.
  • Remember a sales person will tell you anything they think you want to hear. A factory warranty department may tell you everything you don't want to hear. If you really want to know, call Frigidaire and tell them the refrigerator in your RV quit working and ask for some local service centers to see how they respond
