A few days ago (11-7-21) I posted problems with my 7500 generator which I am still researching but I am also having problems with my Freedom 458 inverter/charger my interior control board is not re-acting to my commands, for instance it will not show the condition of my batteries, the invert button will not turn on the invert phase or turn off the invert phase as the invert button stays lit. By pressing the set-up,charge and invert buttons I can get the inverter off even though the invert light button is still on. I know this by plugging an appliance into an inverter outlet. I looked at my manuals in the trouble- shooting sections and they don't seem to address the problems I am having. I hoped that maybe the control panel inside the motorhome could be the problem. I have talked to my mechanic who has done work on the motorhome previously and he will check the system out but he has generally found is that the inverter is bad. He thought that maybe the cost could be 3000 dollars but that was not a quote. Looking at the internet I see these inverters from 1000 to 1500 dollars so his guess is probably way off. One question I have if the repair is too expense why do I need an inverter with a good working generator? Any thoughts or suggestions I would greatly appreciate.
My mechanic also thought that maybe I had a fitting gone bad after I changed the fuel filter, he said that sometimes if the filter was leaking after the change that that could cause the problem. As I mentioned in my previous post that my largest fitting on the filter was leaking and I tightened it to stop the leak. thanks for letting me post this, I think this must be my longest post.
Ed & Sharon
2002 Phaeton
2001 Jeep Wrangler Toad
