pnichols
Dec 05, 2021Explorer II
We take our 24 ft. Itasca non-slide Class C slowly and carefully offroad at times.
- We bought it new and it was based on the E450 chassis instead of the E350 chassis that is most often used for small Class C motorhomes. We wanted the overkill ruggedness, reliability, inexpensive/convenient repair/maintenance, extra weight carrying margin, and solid handling of an underloaded Ford E450 chassis supporting the coach.
- I have stock E450 rims on it, but larger diameter tires on those rims in order to provide more ground clearance.
- The fully mounted spare tire is carried in the rear up between the frame members just like on pickup trucks (for a lower center of gravity and elimination of an up-high bouncing spare ... as when carried on/above the rear bumper), and I carry a 12 ton double extension (for higher lift) hydraulic jack for emergency changing of a tire anywhere on soft/unstable ground.
- We carry five 3-step homemade leveling blocks (plus additional wood pieces) along for leveling flexibility on sloped camping spots and for possible help in getting tires unstuck in soft spots. Wooden leveling blocks aren't as likely to break/split as much on rough/rocky surfaces as composite blocks.
- We did not want any slides so as to provide for maximum shear strength in the walls, more reliability protection from a slide that won't close, less overall weight, less chance of leaks in heavy rains when camped or traveling, help in keeping the overall center of gravity low, and for elimination of any stress damage from slides jiggling slightly when traveling.
- All kinds of tools and spare parts stay in the motorhome at all times so they're always there without having to load them special whenever we go on trips. These include such things as: A full size shovel, a pickaxe, a spare serpentine belt plus a special tool to help mount it, a crowbar, extra engine fluids, a tire puncture repair kit, tire inflation canisters, a full power compressor, Eternabond tape, a caulking gun and tubes of caulking, a remote inspection scope to look at plumbing and wiring in behind cabinets, spare plumbing piping and fixtures, spare bulbs, 12V and 120V extension cords, a high power 12V portable fan, a hand saw for large limbs, an axe, all kinds of flashlights, and the coach came with a built-in exterior roof access ladder to inspect for/repair any roof damage while on trips.
- In addition to the built-in 4000 watt generator powered from the main 55 gallon gas tank and the built-in coach battery charger, we also carry along a portable generator and a portable battery charger. We can charge and keep charged our coach and engine batteries five different non-solar ways.
- And last but by no means least: We carry along a Garmin Mini satellite rescue and text communication device (along with emergency rescue insurance) ... since many times we can be out of range of mobile phone cellular towers.
Our main offroad concerns are - no 4X4, and the width and the height of the coach structure at 101 inches wide and 11'6" tall. But what this non-slide size and non-4X4 package gives us is all the comforts of home way out in many U.S. boondock areas and at purchase and maintenance pricing that we can afford.
So far our most remote trip has been into the Oregon Outback 25 miles each way, during which we had to travel at around 7-10 MPH to keep the motorhome under control and free from damage.
38,707 PostsLatest Activity: Feb 17, 2025
